Results 1 to 6 of 6
Thread: 1998 e38 Valley Pan
    May 2018
    Monmouth Cty, NJ
    1998 BMW 740i
    1998 e38 Valley Pan
    Can anyone help me with good instructions for the valley pan job.
    I used the search bar and did not have success.
    Thank you in advance
    Jun 2008
    Atlanta, GA
    E53, E38, E34, E39T
    Some Places remain unknown because no one has ventured forth. Others remain so because no one has ever come back......
    Feb 2009
    KC North, MO, USA
    1996 740iL
    If you prefer written instructions:
    http://www.magnum1.com/magnum/BMW-74...ey-Pan-740.php
    May 2018
    Monmouth Cty, NJ
    1998 BMW 740i
    Outstanding!
    Thank you Sir
    Thank you!
    May 2018
    Monmouth Cty, NJ
    1998 BMW 740i
    I did the valley pan last weekend - I took my time in my garage and spread it over a Sat and Sunday. I purchased an Earthquake XT battery powered ratchet which really helped a lot with this particular job. When I pulled the manifold out, debris fell into the intake ports on the engine which I ultimately vacuumed out with with a very narrow attachment before re-installing it. The debris consisted of grime and the broken up insulation that is the outer cover for the knock sensor cables. You need to be vigilant with the intake port inspection and cleaning before reassembly. I removed the rear coolant manifold rather than the water pump in order to remove the coolant pipes which are located under the manifold and over the valley pan dead center on the engine. I replaced all of the gaskets that this job allows you to. It takes a few days to get the coolant levels regulated - same as when I replaced the water pump last month. The coolant levels are holding steady for the first time in a while and the engine is running really well.
    Everett, WA, USA
    '01 740i, '93 300ZX TT
    The one thing these don't cover that a FSM will is that you always torque inside to outside and opposites. Don't just tighten down and torque CW or CCW.
  1. (E39/E38) M62 parts (M60 intake, timing chain kit, valley pan, cooling system, etc)
    By {ROn1N} in forum Engines, Performance Parts & Software
    Last Post: 11-21-2015, 06:27 PM
  2. 2000 bmw 740i sport , e38 need help valley pan gasket
    By anqel8 in forum Engine Conversions
    Last Post: 05-25-2014, 08:01 PM
  3. E38 1998 e38 inst cluster and maf for sale
    By cgyacht in forum Engines, Performance Parts & Software
    Last Post: 08-19-2013, 10:06 PM
  4. E38 Wood Center console from 1998 e38 BMW 740i, 740il, 750il with ashtray
    By Waywild3 in forum Interior Lighting & Body Parts
    Last Post: 12-25-2012, 04:30 PM
  5. E38 valley pan replacement parts for sale
    By 350chevrolet in forum Engines, Performance Parts & Software
    Last Post: 01-26-2009, 08:35 PM
