Results 1 to 14 of 14
Thread: ATF fluid
    Feb 2012
    Houston Texas
    2005 BMW X3 3.0i
    ATF fluid
    Hello guys! I changed my transmission on 2005 X3 3.0 fluid and filter over the weekend but sort of nervous of driving it. Heard horror stories of ppl putting wrong fluid in the case. I crawled under and saw GM tag on the side but couldn't make out the numbers on it. At the bottom of pan 83220024359 is a sticker on fluid to use witch come to find out is not available anymore. I ended up using Maxlife ATF only because I had no choice and because I had to move vehicle. I asked a local mechanic on what he recommends, he mentioned zf fluid.. which worries me now. Has anyone used the Maxlife??
    Thanks in advance
    Sent from my moto g(6) play using Tapatalk
    Jan 2016
    Ca
    2001 525it
    Did you search the number in the internet you will find it there
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    83220024359 is Dexron VI , Dexron VI in GM A5S390R (GM 5L40-E) ,83 22 0 024 359 ETL 8072B, 25 L
    On the Maxlife bottle is mentioned: BMW ETL 8072-B, BMW 7045E, LA2634, LT71141
    or more in detail:
    A close-up look at a bottle of Valvoline Max-Life Full Synthetic Multi-Vehicle ATF (automatic transmission fluid).
    According to the back of the bottle, this fluid is compatible with vehicles that require the following:
    GM DEXRON II
    GM DEXRON III
    GM DEXRON VI
    Ford MERCON LV
    Toyota Type T
    Toyota Type T-II
    Toyota Type T-IV
    Toyota Type WS
    Honda ATF-Z1 (not for CVTs)
    Nissan Matic-D
    Nissan Matic-J
    Nissan Matic-K
    Nissan Matic-S
    Hyundai/Kia SP-II
    Hyundai/Kia SP-III
    Hyundai/Kia SP-IV
    Hyundai/Kia SPH-IV
    BMW 7045E
    BMW ETL 80728
    BMW LA2634
    BMW LT71141
    Allison C-4
    Allison TES 369
    Mercedes-Benz NAG-1
    Volvo 1161521
    Volvo 1161540
    Volvo 97340
    Volvo 1273.41
    VW/Audi G-052-025-A2
    VW/Audi G-052-162-A1
    Feb 2012
    Houston Texas
    2005 BMW X3 3.0i
    Thanks a bunch. I did call dealer and the guy gave me a part number which turns out to be a zf fluid. but guess I'm just going to drive and see what happens
    Jan 2005
    Japan
    Did you tell the dealer that you have an automatic transmission? Because telling you that for a GM automatic trans you need ZF fluid sounds strange. Probably they assume you have a ZF 6-speed manual transmission
    https://www.bimmerforums.com/forum/s...-kit-and-fluid
    Feb 2012
    Houston Texas
    2005 BMW X3 3.0i
    Quote Originally Posted by shogun View Post
    Sure did.
    Jan 2005
    Japan
    pls use in future the button "reply", not 'reply with quote', I always have to delete unneccessary quotes
    Feb 2012
    Houston Texas
    2005 BMW X3 3.0i
    Jan 2005
    Japan
    ahh, you found it, I know it is a bit difficult to find when you use a smartphone. Some additional info, in case you want to post pics and upload them on the forum server, then use instead of 'post quick reply' the button "Go Advanced", then a new window will open, text you message, scroll down, there you find "Manage Attachments", Valid file extensions: doc gif jpe jpeg jpg pdf png psd txt zip
    Test forum is here https://www.bimmerforums.com/forum/f...hp?123-Testing
    Feb 2012
    Houston Texas
    2005 BMW X3 3.0i
    Awesome. Thanks my guy.
    And yes very confusing when using smart phone.
    Jul 2011
    Binghamton, ny
    2006 X3, 95 TSI AWD
    I've used maxlife in my gm auto. It likes it.
    Feb 2012
    Houston Texas
    2005 BMW X3 3.0i
    I use it on my Suzuki xl7 and Scion xB.. just added in my x3, so far so good
    Mar 2019
    Phoenix
    i10
    Quote Originally Posted by rene0900 View Post
    Thanks in advance
    https://autofthings.com/what-happens...nion-goes-out/
    Hi.
    If I remember correctly, x3 uses ATF (red stuf).
    Do you remember what color was the old fluid.
    It only comes down weather it uses ATF (red) or pentosin (green). Only some BMWs use pentosing, and they have green sticker saying 'pensotin only' on PS bottle.
    Feb 2012
    Houston Texas
    2005 BMW X3 3.0i
    When I drained, it was difficult to identify what color, someone else changed it before but fluid was super dark. It did had a hint of red. So far so good with Maxlife in it.
  1. Flushing the ATF fluid..
    By yo5bmw in forum 1988 - 1996 (E34)
    Last Post: 05-11-2005, 04:01 PM
  2. '93 325is "Home made" Inspection II - How much ATF fluid?
    By mvelimir in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-05-2004, 12:38 PM
  3. ATF Fluid change on E34 540
    By rwindleyme02 in forum 1996 - 2003 (E39)
    Last Post: 08-18-2003, 09:58 AM
  4. ATF fluid change...something isn't right
    By Filip75 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-18-2003, 10:17 PM
  5. Mobil 1 ATF Fluid good for my transmission?
    By GreenGiant in forum 1991 - 1999 (E36)
    Last Post: 03-03-2001, 07:11 PM
