Hey guys so I bought a new zhp motor I almost have the old engine out but the exhaust flange keeps getting hung up on the control arm and the oil pan gets stuck on the steering shaft. any tips on which way to shift the engine/car to get it out? right now the entire front end is off and the car is jacked up on stands behind the front wheels
I’ve never swapped an engine but 2 bits of info:
- BMW raises the engine+transmission from underneath at the factory
- I believe the only way to get the engine out is to disassemble everything in from of the engine, support the engine+transmission and push the car back away from the engine or move the engine+transmission forward away from the car.
You need to disconnect the steering shaft from the steering gearbox and move it aside.
The exhaust can be maneuvered around the control arm and everything else.
Done several engine pulls and swaps.. you do need to disconnect the steering shaft as stated above, then it will come right out.
Lime Rock Park... the most fun you can have in a mile and a half.
I actually managed to get it out without removing the steering shaft. I ended up just jacking the engine up a bit more untill it cleared the shaft and the control arm. However, make sure you have someone doing this with you because once you clear the shaft it kind of falls back down a little bit so you need a spare set of hands to guide it.
working on my friends car recently uninstalled his steering column, and I actually recommend doing it, you guys werent wrong its iterally one bolt
I would disconnect the steering and drop the front end as well or disconnect the struts and bushings and pull the front end out with the engine.
yes I have a friend that pulls the entire front end as one piece with the subframe
