Results 1 to 12 of 12
Thread: Engine Removal Hang up
    Jun 2013
    Durham, Ontario, Canada
    04 330Ci
    Hey guys so I bought a new zhp motor I almost have the old engine out but the exhaust flange keeps getting hung up on the control arm and the oil pan gets stuck on the steering shaft. any tips on which way to shift the engine/car to get it out? right now the entire front end is off and the car is jacked up on stands behind the front wheels
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    I’ve never swapped an engine but 2 bits of info:
    - BMW raises the engine+transmission from underneath at the factory
    - I believe the only way to get the engine out is to disassemble everything in from of the engine, support the engine+transmission and push the car back away from the engine or move the engine+transmission forward away from the car.
    Jun 2012
    New Mexico
    2003 328i
    You need to disconnect the steering shaft from the steering gearbox and move it aside.
    The exhaust can be maneuvered around the control arm and everything else.
    Jun 2013
    04 330Ci
    Quote Originally Posted by nonturbodan View Post
    Are you absolutely positive you have to remove the steering shaft? I've gotten the pan past but then the engine hits the firewall
    Jun 2013
    04 330Ci
    Quote Originally Posted by MarcoZandrini View Post
    the engine is on a cherry picker and I am sliding it out from the front of the car
    Jun 2012
    New Mexico
    2003 328i
    Quote Originally Posted by Brickk View Post
    Thats what I did. Remove the single torx bolt from the steering gear end, pull the shaft off and move it aside. Takes a few minutes and makes removal and installation much easier.
    Jun 2013
    04 330Ci
    Okay going to try this tonight
    Jul 2003
    Spring, TX
    E36 328is, E39 M5
    Done several engine pulls and swaps.. you do need to disconnect the steering shaft as stated above, then it will come right out.
    Lime Rock Park... the most fun you can have in a mile and a half.
    Jun 2013
    04 330Ci
    Cool
    Quote Originally Posted by Hallatauer View Post
    I actually managed to get it out without removing the steering shaft. I ended up just jacking the engine up a bit more untill it cleared the shaft and the control arm. However, make sure you have someone doing this with you because once you clear the shaft it kind of falls back down a little bit so you need a spare set of hands to guide it.
    Jun 2013
    04 330Ci
    working on my friends car recently uninstalled his steering column, and I actually recommend doing it, you guys werent wrong its iterally one bolt
    Apr 2013
    Mill Valley, CA
    2003 330cic
    I would disconnect the steering and drop the front end as well or disconnect the struts and bushings and pull the front end out with the engine.
    Jun 2013
    04 330Ci
    yes I have a friend that pulls the entire front end as one piece with the subframe
  1. Engine Removal...
    By icemann633 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-11-2005, 01:35 PM
  2. need some engine removal tips
    By jmott in forum 1991 - 1999 (E36)
    Last Post: 03-12-2005, 11:15 PM
  3. engine removal
    By ///M4life in forum 1992 - 1999 M3 (E36)
    Last Post: 10-06-2004, 04:36 PM
  4. Engine removal
    By jsvizijr in forum 1988 - 1996 (E34)
    Last Post: 03-16-2004, 09:49 PM
  5. Engine removal procedures
    By jsvizijr in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-24-2004, 03:40 PM
