Results 1 to 7 of 7
Thread: How can oil temps vary so much over a single lap?
    Jun 2002
    California
    01 MCoupe, 10 535 SW
    Or even corner to corner.... Bad sensor?
    Aug 2012
    Central, MD
    1995 M3
    Where's the sensor?
    Jun 2002
    California
    this is from the ECU. via CANbus
    Apr 2002
    Broomfield, Colorado
    Definitely not oil temp in that graph. You didn't get to 330F and just keep trucking. You also didn't drop 60 degrees in one lap without coasting.
    Sensor, ground wire, Math problem (number displayed is always a calculation), ECU reading wrong sensor and reporting as oil temp - no way that number is correct.
    2002 BMW M Roaster.
    1998 BMW 328is SCCA E Production road racer.
    Toronto, Canada
    85 325e M52t - 06 330i
    Yeah COMZ3 is right. That's not the oil temp channel.
    Did you define it yourself or is that the AIM protocol definition?
    Jun 2002
    California
    I just recently got the AIM SOLO2 DL. I'm using the e 46 M3 CAN protocol. (I have an S54 M Coupe). It does not read everything, I can get RPM, Pedal Position, brakes on/off, oil and water temps along with steering angle. If I'm driving normally, the temperatures look fairly reasonable. (screenshot from a street drive today). Since the track day above, I have changed the oil level sensor since I would occasionally get the low oil light only to find it was normal when I checked it.
    I did notice the oil temp gauge spike last time at the track, usually the hottest is shows is 260/270. but it was pegged at max only to come down fairly quickly.
    Nov 2005
    MA
    Cayman S, Golf GSW, E30
    I"d post on the Aim User Group on Facebook. Lots of knowledge there.
  1. How difficult is an oil temp/pres. gauge install?
    By cc///m3 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-08-2001, 11:06 PM
  2. Anyone ever swap MPG gauge w/euro oil temp?
    By Ian in forum 1992 - 1999 M3 (E36)
    Last Post: 07-20-2001, 11:18 AM
  3. Need help with Oil Temp Gauge
    By Seedster in forum 1992 - 1999 M3 (E36)
    Last Post: 07-02-2001, 09:17 PM
  4. Need help with Oil Temp Gauge (please!)
    By Seedster in forum 1991 - 1999 (E36)
    Last Post: 07-02-2001, 06:48 PM
  5. do 98-99's have an oil temp sensor factory installed?
    By RS in forum 1992 - 1999 M3 (E36)
    Last Post: 05-30-2001, 07:23 PM
