Results 1 to 8 of 8
    Mar 2019
    coeur d'alene Idaho U.S.A
    2001 bmw x5 e54 m54
    ccv valve system replacement
    Hi, i'm new and haven't seen anyone post anything new on the subject (last discussion 2011?) I need to replace my ccv system on my bmw x5 2001 e53 m54.
    I had a few questions. The FCP euro site has the cold climate pcv breather kit
    https://www.fcpeuro.com/products/bmw...11617533400kt6
    It's also listed on amazon for waaaaaay less.
    https://www.amazon.com/Sentinel-Part...y&sr=8-1-fkmr0
    So i shouldn't buy the cheaper one right?????? I'm tempted. $182 is alot for a kit.
    I live in north idaho, it gets to the 9-15 degrees at night during the winter so i'm assuming in need the cold weather version right? A shop quoted me at $550 to replace it and i'm assuming they wouldn't put the cold weather version on my car.....Otherwise they would have charged me more? The job takes a while and the parts are 200$?
    Dec 2013
    Chicagoland area
    EXOTICS
    Have you bothered to compare the warranties?, you get what you pay for.
    Cold weather version would be best for you.
    Jun 2014
    northern michigan
    95 M3 - 06 X5 3.0
    I plan to do this one on my m54 e53.. For bulletproofing, because I'm scared of hydrolock, and I hate the mayo..
    Probably the cheapest option too..
    https://xoutpost.com/bmw-sav-forums/...-problems.html
    E36 M3 S50 - E53 X5 M54 - 1980 Porsche 931 - 2001 Impreza RS25
    Mar 2019
    2001 bmw x5 e54 m54
    I am going to remove the intake manifold (i need to right?). Are there other parts i should replace while the manifold is off that go bad regularly?
    I've done the CCV job countless times. Never once have I removed the intake manifold.
    Mar 2019
    2001 bmw x5 e54 m54
    Do you have an x5? Not sure what kind of room other models have but the x5 is packed. Do you move parts out of the way or do you use tools that fit in tiny places? Not removing the manifold sounds great.
    Jan 2016
    Ca
    2001 525it
    Replace the coolant plastic pipes while your manifold is off and replace all those little vacuum hoses and rubber cap at the end of the mainfold
    I'm a BMW tech. I've done the job on every vehicle ever equipped with the M54 engine. If you remove the DISA valve and throttle body, you'll see what you need to do. And unbolt the three bolts/nuts holding the wiring harness unit on so it'll move around and give you some access.
  1. Replacing CCV valve-costs?
    By nomadic80 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-26-2013, 10:31 AM
  2. After replacing the CCV Valve 3 cylinders misfiring
    By tman62 in forum 1999 - 2006 (E46)
    Last Post: 01-29-2013, 04:21 AM
  3. cleaned ccv valve, replaced the hose as well now getting p0173
    By bimmerrob10 in forum 1991 - 1999 (E36)
    Last Post: 06-24-2012, 07:59 PM
  4. Price check on CCV valve replacement
    By dahifi in forum 1996 - 2003 (E39)
    Last Post: 10-04-2011, 09:03 PM
  5. Increased oil consumption after CCV valve replacement?
    By sammk in forum 1999 - 2006 (E46)
    Last Post: 07-22-2009, 04:04 AM
