Results 1 to 14 of 14
Thread: Noob Question: Where to buy Geniune BMW parts
    Mar 2019
    San Luis Obispo, CA
    2001 BMW 540i
    Hey guys, I am new here and I have been looking around (maybe not good enough) and I can't find genuine bmw part. I am looking for a Camshaft position sensor, I know to not skimp out on electrical parts so, that's why I am going for Genuine BMW. Also, its my first time buying a part online so, I wouldn't know where to look or what places to trust.Where do you get them?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to E39 forum from E39 DIY
    Jan 2016
    Ca
    2001 525it
    Fcp euro I would replace both ntake and exhaust sensors if there's no history of replacement
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Welcome to the forum.
    What code are you getting, not P0011? How many miles on the car?
    FCP should show you which parts are genuine and which are aftermarket.
    Oct 2017
    Beaverton, Oregon, USA
    2001 E39 540i A, 207 k
    Many online vendors -FCPEuro, PelicanParts, AutohuasAZ, EEuroparts, ... - carry BMW genuine parts.
    First, get the exact part # from realoem,com , then shop around for the part.
    Jan 2014
    Buenos Aires, Argentina
    '97 523i5 - 99' 540iA
    not eeuroparts! they suck [/dailyrantabouteeuroparts]
    Diehard E39 driver.
    I'd rather die or take a walk before driving an E60 or any BMW made after Y2K.
    ​"Your momma's so ugly she makes Bangle cars look nice"
    Oxnard (Ventura), CA
    99528it 02525it 04325it
    RmEuropean is another good source but you have to order over $65 bucks to get the free shipping.
    Oct 2017
    There is also a BMW dealer that has -surprisingly- a good inventory and prices on BMW parts.
    (parts.bmwofsouthatlanta.com) . Check it out, and always, shop around.
    Omaha, NE
    1998 528i 5-spd 102K
    I use "Husker BMW" in Lincoln, Nebraska, their price is very good.
    Mar 2010
    SF Bay Area, CA
    2003 BMW 530i (Auto)
    Quote Originally Posted by easymoney View Post
    A couple of O2 sensors (let alone 4) will take care of that real quick
    Mar 2019
    San Luis Obispo, CA
    2001 BMW 540i
    wow guys thanks for the replies! I haven't been in a while. I thought I would get email notifications but i didn't.
    Mar 2019
    San Luis Obispo, CA
    2001 BMW 540i
    Sorry for the late reply JimLev, as I mentioned before I thought I would get email notifications automatically when someone replied to the thread.
    Anyways, to give you a full break down of what happening. I took into the shop like a month ago because the engine service light was on and it felt like the engine of kilter, it was rattling the whole car but, only in low gears like 1st and 2nd. Once I got up 30mph plus it was fine. The only thing was that an unusual amount of whit smoke would come out of the exhaust pipe. I'm assuming it was from unburnt gas. Once I got into the shop they replaced the spark plugs and put in a "tester" mass air flow filter that adjusted the fuel trims because the it was running slightly rich.
    Now, I got the car out of the shop. The service engine light comes on again. This time I wanted to take matters into my own hands and figure it out if I could with the help of the forums of course. Since the I posted the SES has came on twice and I got the codes read at autozone for both time
    s
    The first one reads:
    "ASE certified Master Technician have seen this issue on your type of vehicle and the most likely solution is: Replace Camshaft Position Sensor"
    Side Question: How Reliable Is that statement
    Error Codes Read
    P1341
    Multiple Cylinder Misfire with Fuel Cut-Off
    P1343
    Misfire Cylinder 1 with Fuel Cut-Off
    P1345
    Misfire Cylinder 2 with Fuel Cut-Off
    P1351
    Misfire Cylinder 5 with Fuel Cut-Off
    P1357
    Misfire Cylinder 8 with Fuel Cut-Off
    Suggested Parts
    Distributor
    The Second one reads:
    Error Codes Read
    P1341 Multiple Cylinder Misfire with Fuel Cut-Off
    P1343 Misfire Cylinder 1 with Fuel Cut-Off
    P0171 System Too Lean (Bank 1)
    P1345
    P1351
    P1357
    Suggested Parts
    Distributor
    I think the P0171 comes from the shop changing the mass air flow. Also, I just wanted to know if the suggested things are correct. The SES turned off again and the car is 140k. Hope you see this!
    Jan 2015
    Shreveport Louisiana
    id be looking for a vac leak. getting your own reader that shows live data will help you a lot in diagnosing this issue. it doesnt seem in any way related to a cam position sensor.
    Oct 2017
    Well, the codes clearly state misfires on cylinders 1, 2, 5 and 8.
    So, first I'd check the spark plugs and the coils on those cylinders. Replace them if necessary.
    And no, it is NOT the camshaft position sensor.
  1. Best place to buy OEM BMW parts?
    By Jack79 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 10-11-2007, 10:05 PM
  2. Noob question.. i dont see why BMW did this, enlighten me
    By TH3 Shifty in forum 1992 - 1999 M3 (E36)
    Last Post: 10-06-2007, 07:26 PM
  3. Noob Questions: Hope to buy soon
    By Incompatible in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 09-04-2007, 04:35 PM
  4. Where to buy used BMW parts?
    By misterphat in forum 1996 - 2003 (E39)
    Last Post: 12-01-2006, 03:15 AM
  5. Got a question on where I can buy this BMW part.
    By gmannino in forum 1988 - 1996 (E34)
    Last Post: 02-28-2006, 02:33 AM
