Results 1 to 11 of 11
Thread: Wheel offsets for 93 740l. 93 is a E32?
    Mar 2019
    Redwood city Ca.
    1993 740l
    I want to install 18" style 37 wheels on my 93 740l.
    The stock rim is 20mm offset.
    I purchased 2 rims for $150., which are in pretty good shape.
    One rim is 9 1/2×18 offset 25mm. This one fits.
    The front is 8×18 offset 13mm. Sticks out. So l'm asking if I go to 25mm should it fit?
    Also wondering what year and models have these wheels?
    Thanks for your time! I'm kinda new at the BMW game
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Welcome to the forum.
    I'm not quite understanding why anyone would buy one wheel for each axle, especially when one of them doesn't fit?
    Just go to Tirerack.com, enter the car, and look at the choices of aftermarket wheels. That will likely give you the info you need to buy 4 wheels that fit. Offsets are provided.
    Chris Powell
    BMWCCA 274412
    Mar 2019
    Redwood city Ca.
    1993 740l
    I was wondering if l could put the rim that doesn'the fit, on a mill and use a fly cutter to machine off the mat. How about clearance with the caliper?
    Mar 2019
    Redwood city Ca.
    1993 740l
    As l said l got them both for $150. I wanted to get them to see what l was up against.
    The car was wasted on one side. That'said why so cheap
    It was a package deal.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Are you hitting the struts, or the fenders?
    If you are hitting the fender, yes you will need to find a rim with a higher ET.
    If you are hitting the struts, then you can use a spacer to push it out.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    NW suburban Chicago
    hiss by my window
    '93 is the E32 chassis, 20mm is the correct offset
    It is well known that 18" wheels will make this car ride like shit, it wasn't designed for them. Any suspension wear will be magnified ten fold as well. If you choose form over function don't say you weren't warned.
    Ditch those silly wheels that don't fit anyway ($150 is no bargain for a pair of mismatched garden hose reels) and buy a proper set that actually fit. E38 wheels in 16" are inexpensive, FIT and readily available.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Moved to E32 forum, see here under wheels upgrade http://www.bmwe34.net/E34main/Upgrad...ls_upgrade.htm
    USA
    e34 540ia/e32 740il
    Quote Originally Posted by moore4225@gmail View Post
    8X18 ET13 offset is the oem size for the front m-parallel wheels on the e38 and e31. What exactly do you mean by "doesn't fit"? et13 on an 8" wheel should be about perfect offset on the front of an e32. What tire size are you using? If the wheels have the stock e38 tires on them they are way to big, and will rub on an e32.
    NYC & Long Island & So FL
    '93 740il '84 633Csi
    Melbourne, Australia
    '88 750iL, '01 530iT
    Sounds like they're E38 wheels, which means the tyres would be the wrong size (diameter) for E32 to begin with.
    I've run 15mm offset tyres on mine (from E31 8 series) with no problem... but on 225 width tyres.
    Maybe a 225/60R18 tyre on the front would suit, and would probably track better on the road with the E32's rather sensitive front suspension set up.
    1988 E32 BMW 750iL Bronzitbeige "....4372381"
    2001 E39 BMW 530i Sport touring Cosmosschwarz "....GL80561"
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    All about fitting alternative alloys here:
    https://www.meeknet.co.uk/e31/Timms_..._tyre_page.htm
    My BMW Repair YouTube Channel
  1. Sparco steering wheel adapter '91 E30 to '93 E36
    By Scany1980 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 07-22-2009, 04:05 PM
  2. Wheels by BBS from a 93 325IS
    By Doonbugg in forum Wheels and Tires
    Last Post: 11-18-2008, 08:13 PM
  3. will m coupe wheels fit on my 325is 93
    By partouza in forum 1991 - 1999 (E36)
    Last Post: 11-07-2003, 11:05 AM
  4. wheel offset
    By monterey in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 07-18-2001, 02:17 PM
  5. Quick wheel offset question... thks
    By TC3 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 05-21-2001, 12:02 AM
