Results 1 to 3 of 3
Thread: 735i EML rough idle and missing road-speed signal in DME
    Sep 2010
    Estonia
    2000 BMW 740i
    Hello, I'm having issues with my E32.
    It is a original 730i but I've changed the engine to 3.5. The problem is with rough idle. The engine has been rebuild by myself with new OEM gaskets. I ordered a used DME for 3.5 engine and coded with C32A variant code. (Before was 675E without cat). I cannot find any vac leaks. O2 sensor issue?
    Another problem is with road-speed signal. DME doesn't show any speed while driving. Any suggestions?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    as for the road speed signal check the sensor, wiring and plug at the rear of the final drive http://www.bmwe34.net/E34main/Mainte...eed_sensor.htm
    The signal goes from there to the cluster coding plug where it is converted, details here http://www.e38.org/e32/BMW_pdfs/INST_info.pdf
    Sep 2010
    Estonia
    2000 BMW 740i
    Speedometer works.
  1. E36 road speed signal error after swapping ms41
    By aimanad in forum Forced Induction
    Last Post: 05-22-2014, 07:38 AM
  2. My 85 735i has rough idle issues
    By gtj735i in forum 1978 - 1987 (E23)
    Last Post: 11-20-2011, 07:34 AM
  3. Road-speed signal
    By ogorek in forum 8 Series (E31)
    Last Post: 09-24-2011, 06:01 AM
  4. Replies: 3
    Last Post: 05-15-2008, 08:30 AM
  5. Rough Idle, engine hesitates/misses/bogs down/vibrates
    By Greg M in forum 1991 - 1999 (E36)
    Last Post: 06-08-2005, 02:28 AM
