Hi All.
First post here and it's because I've run into a problem with my BMW.
Currently have a 2013 535ix M-Sport and the front windows on the driver and passenger side wont' roll down.
The back windows do and I check with all the switches on each door.
I've checked the fuses in the glove box and they all appear to be fine for the corresponding fuses.
Car has only 60k miles.
Any suggestion on what I could be missing?
Seems unusual that you would have both windows stop working, are you trying it only from the control panel on the driver side door? what happens if you try to operate the passenger window form the switch on the passenger door? if that works it might just been the control panel on the driver door.
Another thing I might try disconnecting the battery for about 30 seconds and see if something got scrambled.
If not check for faults in the frm module
