RM European Auto Parts
Results 1 to 6 of 6
Thread: HELP MY E90 won’t start
    Dec 2018
    Van Nuys,CA
    2008 BMW 3281
    I’m gonna explain Wht happened, I drove to my friends house. 6 hrs later I get in to go home and everything seemed fine lights on dash came on I push the clutch peddle and nothing not a sound. Couldn’t figure it out so had I towed home. So I started to tear it apart to get to the starter. Took it to get tested and it was bad. So while I’m in the motor decided to do my valve cover gasket and new valve cover because mine cracked. While this is going on for off n on 3 weeks battery died so it was sitting for a moth with no battery. Put the parts back in along with intake manifold gaskets . So now I go to start it and it’s cranking but won’t turn over. I don’t get it
    ALSO THESE CODES POPED UP:
    EKPS- fuel pump control
    FRM2- footwell module 2
    CAN- communication analysis
    JBE2- junction box electronics
    INSTR- instrument cluster
    IHKA- integrated automatic heat/air conditioning
    so I’m pretty much stuck with no clue in Wht to do pls help with any advice. Thanks
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    did you fix the problem with your battery ? Is the battery fully charged? https://www.bimmerforums.com/forum/s...ing-my-battery
    Dec 2018
    Van Nuys,CA
    2008 BMW 3281
    Yes I replaced the battery n it’s fully charged,
    Joppa, Md
    99 M Coupe,04 K1200rs
    fuel pressure?
    Quote Originally Posted by Sikwit23 View Post
    The fuel pump code would cause a no start, shoot a little starting fluid in the air intake while cranking if it starts momentarily, the pump or a fuse/relay is kaput., PS,"cranking" is turning over in our jargon, starting is different.
    Dec 2018
    Van Nuys,CA
    2008 BMW 3281
    Ok I’ll try that rite now, thanks didn’t know about the whole cranking thing. But I got it now. I’ll post Wht happens whn I try it.
    New York
    1974 2002, 2009 128i
    Are those fault codes present or not? If not they may be artifacts of the low battery condition. Clear faults and see what comes back up.
    Life's tough. It's tougher when you're stupid.
    -John Wayne
  1. Help e90 wont start
    By sirrom in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 01-02-2019, 07:41 AM
  2. Please help! e90 wont start/crank
    By e90machine in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-03-2014, 09:48 PM
  3. help e90 wont start has new batt
    By siccycle in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 07-24-2012, 11:27 AM
  4. Help:97 e38 wont start: clicking...what to do?
    By kto in forum 1995 - 2001 (E38)
    Last Post: 02-19-2004, 06:16 AM
  5. Please help, my car wont start!!
    By dfwmpower in forum 1992 - 1999 M3 (E36)
    Last Post: 01-04-2004, 06:57 PM
