Results 1 to 12 of 12
Thread: Violent vibration after m52 swap
    Jan 2017
    Suwanee
    1998 BMW 318i Sedan, M52
    *SOLVED* Violent vibration after m52 swap
    Hello everyone, I will start by saying I have abused the hell out of the search function and have found many solutions to this problem which I have read deeply into. I have a 1998 E36 318i with a recently swapped M52 using the stock getrag.
    I have been chasing this vibration ever since I got the swap done and drove the car for the first time. The entire car vibrates extremely violently (May be more pronounced due to solid condor motor and trans mounts) mostly in 3rd-5th gear and happens when getting on the throttle and gradually diminishes when letting off. I can feel it from under where the driveshaft is placed. The car is undrivable, the guibo bolts came off on their own on a ten minute test drive.
    I have replaced the flex disc, center support bearing (preloaded correctly), put in a known working used driveshaft, replaced driver side rear wheel bearing and CV axle (both were wobbling) and the problem continued to persist.
    Now I am thinking differential but I don’t see how it would go bad as the car drove as smooth as can be before the swap was done and I am about ready to set this car on fire.
    Can anyone point me in the right direction? I have replaced all the main components that seem to cause driveline vibration but perhaps I am missing something. Differential bushings or bearings?
    One last thing, I don’t know if this may have anything to do with it but just thought i’d put out there that the motor does hesitate and idle rough on cold start and smooths out when warmed up. Sounds like a vacuum leak/misfire which I plan to take care of soon. ECU throws codes for fuel trim and o2 sensors
    Thank you all
    Jan 2019
    Australia
    BMW 92e36 320i,
    Sounds like the driveshaft is out of phase. Have you had your driveshaft balanced?
    Jan 2017
    Suwanee
    Oh yes I forgot the mention, I had the two separated halves lined up at the white dots as well
    Jan 2019
    Australia
    BMW 92e36 320i,
    still would pay to get it balanced
    Jun 2016
    California
    E36 325is
    Quote Originally Posted by vjefhsb View Post
    Did you put a 325/318 pilot bearing in the M52? Might want to do that...
    Jan 2017
    Suwanee
    Quote Originally Posted by Tapanui View Post
    Just learned the flex disc must be oriented the correct way according to the indicating arrows. Will take a look tomorrow and update results
    Quote Originally Posted by FiberFast View Post
    Are you talking about the pilot bearing that is replaced with a clutch kit?
    Jun 2010
    NY
    1997 328i
    Get rid of the solid mounts, fix vacuum leaks.
    McKean township Pennsylva
    1999 M3 , 1999 328is
    I've had good success putting a go-pro camera under my car to try to identify offending vibrations.
    Jun 2016
    California
    E36 325is
    Yes, that one. Is the pilot bearing you used for the M52? Because the M52/ZF pilot bearing accepts a 12mm spline nipple. The Getrag G260 has a 10mm spline nipple. You must use a 318/325 pilot bearing. It is my suspicion that the vibration you are experiencing is coming from your input shaft moving around about a mm or two every now and then... Bout to drop my trans an replace mine... Its the only thing left. I have similar type of problem on my M52 swapped 325is.
    The pilot bearing is a very logical possibility. It being a mm off would cause tremendous vibration.
    Jan 2017
    Suwanee
    The problem has been solved! There were only three driveshaft bolts bolting the driveshaft to the guibo and the transmission output shaft when there should’ve been 6. The guibo must also be oriented the correct way with the arrows on the sides pointing towards each flange.
    I believed I still used the m52 pilot bearing with the getrag, however the car feels smooth even with the solid mounts.
    Jun 2016
    California
    E36 325is
    Curious. I am going to dig into my clutch soon, I will let you know what I discover. For sure my new 325is pilot bearing does not fit on my 328 alignment tool though. Might want to be something you look into before you trash your transmissions input shaft bearing and seal. The component people always complain about going out on those getrags... . . . Glad you found the source of your vibrations, now they are good ones.
  1. Vibrations after tranny swap?
    By Don corns in forum 1995 - 2001 (E38)
    Last Post: 04-07-2014, 03:05 PM
  2. Code 1222 after M52 swap in OBD1 E36 chassis
    By Boarderx192 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-01-2013, 02:40 PM
  3. After M52 swap, getting code 1222
    By Boarderx192 in forum 1991 - 1999 (E36)
  4. Engine Vibration after manual swap.
    By Pavlo in forum 1991 - 1999 (E36)
    Last Post: 12-24-2012, 08:53 PM
  5. Bad vibration after transmission swap - sanity check?
    By madslackin in forum 1992 - 1999 M3 (E36)
    Last Post: 07-26-2006, 09:49 PM
