Results 1 to 4 of 4
Thread: 1999 bmw 323 overheating
    Mar 2019
    Hinton, wv
    1999 bmw 323i
    Took this car for a test spin today. Temp gauge got up I the red. Shut the car down and checked the top coolant hose. It was hot to the touch. Bottom hose, not hot at all. Maybe radiator stuck up? Well anyways. I turned the car back on and the cooling fan is not switching on. They should cut on when the car reaches a certain temp. And I’m certain it was at the correct temp lol. But even if the fans didn’t come on does that explain why the bottom hose was cold? Didn’t see any smoke and there wasn’t any water in the oil.
    Any tips? Is this common?
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    There are a dozen reasons for an E46 M52TU or M54 to overheat. Some are fatal.
    You're considering buying this car?
    A single trip to the red can kill this engine dead.
    Run away, unless you want to replace the engine and the entire cooling system.
    Chris Powell
    BMWCCA 274412
    Mar 2019
    Hinton, wv
    1999 bmw 323i
    When I said test drive I meant that I tested it after I fixed the driveshaft in it. I paid $400 for it. If the motor is toast then oh well. I’ve got connections for other engines. I would just like to salvage this one if at all possible.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    It could be radiator, waterpump, or even the thermostat not opening properly, at the age of that car, these should both be replaced without a second thought.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
  1. 1999 bmw 323 si radio code
    By camino in forum 1991 - 1999 (E36)
    Last Post: 12-17-2010, 08:01 PM
  2. 1999 Bmw 323i overheating
    By mb1171 in forum 1999 - 2006 (E46)
    Last Post: 02-16-2009, 03:47 AM
  3. 1999 BMW 323,5 speed man. 61000 mi. Pennsylvania
    By slim17265 in forum 3 series & Z Series
    Last Post: 10-28-2008, 06:06 PM
  4. For Sale: 1999 BMW 323 IS $8500
    By wslyminski in forum 3 series & Z Series
    Last Post: 09-11-2008, 11:47 AM
  5. 1999 BMW 323 CONVERTIBLE manual trans
    Last Post: 08-05-2007, 03:01 AM
