Results 1 to 5 of 5
Thread: Windows and sunroof not working when I start engine. - solved
    Nov 2017
    Bulgaria
    e32 730 V8
    I have e32 730 m60 sept 93, after one year restoration, all windows and sunroof doesn’t work when I start the engine, when the key is on contact, windows and sunroof work perfectly, but when engine go on, they stop, we try start column we open gm module but everything is ok, do you can help me. Thanks in advance.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Did you already check the fusible link which goes from the battery to the fuse box under rear seat driver side? The third picture http://www.bimmerboard.com/forums/posts/377728/ the first 2 pics is the other fusible link which goes to engine bay to supply power to the e-box. check for haircracks http://www.bimmerboard.com/members/s...ible_E32_1.jpg
    Do you have another GM and RM = relay module next to the GM for testing?
    Wiring diagrams are here http://shark.armchair.mb.ca/~dave/BMW/e32/
    Nov 2017
    Bulgaria
    e32 730 V8
    Can I try with GM and RM from e34, for test, and which year model must be?
    Jan 2005
    Japan
    you can try. But at one date there was a change, but try anyway, nothing dangerous can happen. Here the info, but that is based on US version, maybe for your EURO version the changes were at different dates.
    Looks like there is a difference between E34 built before and after 9/1991 production date, if I interprete that info right:
    "E34 vehicles produced 9/91 and later have different central locking system components from earlier E34 vehicles"
    This Service Information Bulletin supersedes S.I. 61 01 92 (3460) dated January 1992. It incorporates additional information on the new General Module software for E32/E34 vehicles. Please remove and discard S.I. 61 01 92 (3460) dated January 1992 from your S.I. Binder.
    SUBJECT: New General Modules (GM)
    MODELS: 7 Series (E32), 5 Series (E34)- Vehicles produced 9/91 and later
    Situation: New general modules have been used in production since September 1991 in all E32 and E34 models. The software has been completely revised (details of these revisions are found in the attachment to this Service Information Bulletin). Part numbers have been changed to reflect these revisions, as listed below, as of September 1991. Model Part Number
    E32 61 35 8 356 095,
    E34-up to 61 35 8 356 095 9/91 production
    E34-9/91 and later production 61 35 8 355 812
    Note:
    E34 vehicles produced 9/91 and later have different central locking system components from earlier E34 vehicles; therefore, P/N 61 35 8 355 812 is used only in E34 vehicles produced 9/91 and later, P/N 61 35 8 356 095 can be used in E34 vehicles produced prior to 9/91, and in all E32 vehicles. When the general module is connected to the vehicles electrical system, it will recognize (and store in memory) the vehicle configuration, such as:
    - with/without power windows
    - With/without power sunroof
    - with/without wiper contact pressure control
    - with/without headlight washers
    Important Information
    All general modules must be plugged in only after disconnecting the vehicle's battery. If the vehicle's battery is connected when the GM is installed, undefined signal contacts can cause an incorrect vehicle configuration to be stored, resulting in the impairment of
    one or more of the above-mentioned systems. If one or more of the GM functions are impaired in this matter, the GM can be "cleared" by disconnecting the vehicle's battery for at least ten seconds.
    GM Function Changes E32/E34 (Beginning with 9/91 Production)
    - Repeat and Time interlock for headlight washers:
    · Time interlock: 3 minutes
    · Headlight washing at fifth windshield washing after time interlock.
    - Intensive washing pump operating time reduced from 3 to 2 seconds
    - Minimum interval for intermittent wiping is programmable down to 2 seconds (previously 3 seconds)
    - Increased wiper contact pressure during windshield washing cycle is now also provided during dry wiping portion of the cycle (previously only during washer pump operation).
    - Previously, the GM would react to opposing signals (eg., an unlock signal while trying to lock, as with a defective microswitch) by carrying out the first command, then the opposing command (e.g., locking, followed immediately by unlocking).
    Repeating the first command then results in carrying out that command (e.g., try to lock again, and locking is now carried out).
    This function ("Asynchronous Position") is omitted in the new GM for all E32 models and E34 models prior to 9/91 (P/N 61 35 8 356 095), and remains in the new GM for E34 models after 9/91 (P/N 61 35 8 355 812) only for central locking commands "lock" and "double-lock".
    - After unlocking is performed due to crash sensor activation, the locking command is now reactivated by double-locking with the key from either the driver's or passenger's door.
    - The "one-touch" operation of windows has been expanded to include all four windows in the opening direction. The driver's window still has "one-touch" operation in both opening and closing directions. Interruption of the "one-touch" feature of the driver's window in the closing direction is still accomplished by depressing any window switch (in any direction), or by depressing the sunroof switch in the "tilt" direction (provided the sunroof is not already in the "tilt" position). Interruption of the "one-touch" feature of the sunroof in the closing direction is still accomplished by depressing the sunroof switch (in any direction).
    - The switch-off delay of the interior lights which occurs after entering the vehicle and closing the driver's door has been reduced from 20 seconds to 15 seconds.
    Nov 2017
    Bulgaria
    e32 730 V8
    Update: the problem is solved. With exchange of GM and RM modules. Now everything works.
  1. 1994 E36 325is Windows and Sunroof not working
    By motoyoyo in forum 1991 - 1999 (E36)
    Last Post: 11-29-2023, 05:47 AM
  2. Power windows and sunroof not working
    By Dave V in forum 1988 - 1996 (E34)
    Last Post: 09-05-2015, 12:26 AM
  3. Short on fuse #1..Windows and Sunroof NOT working!
    By MANUALmobile in forum 1991 - 1999 (E36)
    Last Post: 05-07-2010, 11:22 PM
  4. Windows and Sunroof not working when doors shut.
    By Papa316Smurf in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 02-05-2008, 01:37 AM
  5. Windows, Gauges & Sunroof Not Working???
    By bimpressions in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-27-2005, 07:25 AM
