While driving the transmission gear came (gear with exclamation), I pulled over and parked at a parking lot. I turned of the engine and tried to start it back, this when the problem started. I noticed on the gear shifter all light are ok. I can move the lever from P to N, D and M no problem all lights light up, but the Dash board does not change it just stay in in "S" - The only time it changes is when I go down to Manual, it shift to M1.
So far these are thing what I have tried.
1. Disconnect battery - even waited for over 24 hours.
2. Tranny reset - pressing gas pedal for 30 seconds.
3. Check tranny fluid - all good here.
4. Disconnect and reconnect the electric connector next the tranny.
Don't know what else to do here - please help....
There should be codes(s) for transmission stored in the memory - find a shop that has the right diagnostic equipment for BMW and have them read transmission codes. Exclamation mark with the gearcog is not a good sign.
The gear ! Sign disappeared after I shut off the engine. I was expecting for that to stay. I do have BMw code scanner no trouble codes found..
Could it be the valve body?
What kind of scanner are you using, as some cannot read transmission codes.
Darin
Current:
Past:
79 525 euro Green/Green RIP
M-Flight Member
Yeah, may be you are right.......I have the cheap BMW scanner I bought 4 years ago at amazon. I have the Creator C310 model, helped me few times to diagnose service engine light.
Yeah, if you are on a budget and have other cars, a Foxwell would be a good choice. If not, and you only have older BMW's <YM2008, it would be worth looking at getting INPA. INPA is BMW's diagnostic program, and with a laptop plus a 30 dollar cable, you can talk to all the modules on that car.
Darin
Current:
Past:
M-Flight Member
Thank you for the advise. I see amazon sells the CD and cable together for under $30.00 worth the investment.
