Results 1 to 2 of 2
Thread: Necessary to replace VANOS bolt a second time if need to adjust it?
    Jul 2014
    West Sacramento, CA, USA
    2006 BMW 330i
    I just finished installing new VANOS bolts after having the units both removed to fix broken head bolts. I aligned everything with the locking tools, but then did a final check after removing them, by rotating the crankshaft two turns and then trying to put the tools back on. The exhaust camshaft was slightly off-position, so in order to install the camshaft lock tool, I had to turn the crank slightly farther and then back slightly. I'm thinking I should remove the exhaust bolt, rotate the exhaust cam slightly, and reinstall the bolt. But would that mean I would need to buy yet another new bolt?
    According to BMW, yes, you do. They are torque to yield bolts. In reality, probably not, but that's just a risk I wouldn't take for the price of a cheap bolt.
  1. M62TU Impulse Wheel VANOS bolt loose after timing jobP
    By IDoSeaDoo in forum 1996 - 2003 (E39)
    Last Post: 07-03-2019, 06:30 PM
  2. Gonna replace VANOS seals, but not thinking I need to replace VCG
    By GlassCity325 in forum 1999 - 2006 (E46)
    Last Post: 03-03-2013, 07:53 PM
  3. Vanos Bolt Replacement!!
    By tonggi in forum New York / New Jersey / Connecticut
    Last Post: 03-13-2012, 11:58 AM
  4. Replies: 0
    Last Post: 07-09-2004, 05:10 PM
  5. time necessary for replacing belts?
    By 1995red318i in forum 1991 - 1999 (E36)
    Last Post: 04-19-2004, 05:25 PM
