Results 1 to 12 of 12
Thread: Question about Borg Warner S257 sx-e
    Oct 2018
    Eugene
    Working on it
    I am beginning assembly of my m50b25 project. It has been bored over to 84.5mm, 8.8:1 weisco pistons, eagle rods, and cut ring head gasket. I am leaning towards the Borg Warner s257 sx-e (purchasing from agpturbo), but am curious about turbine housing options. What size a/r housing is going to get me into boost quickest (I'm thinking .63) for my power goal of 450-500 whp? Also, I'm assuming I want the 'open 4 bolt outlet' option to mate it to my RSI t3 top mount manifold?
    Thanks for any input.
    Apr 2006
    Minnesota eh?
    86 325es
    The .63 will definitely spool faster at the expense of back pressure. Since you have good pistons, low compression, and only 2.5 liters, I think the .63 is going to be a better choice than the .82. If you had a 2.8 or 3.0, or if you had stock pistons I probably would have recommended the .82.
    i would get the 3” v band outlet rather than a 4 bolt outlet.
    Also what part number of piston did you get? Was going to check for you quick to make sure you got the ones for 135mm rods rather than 140mm
    Oct 2018
    Eugene
    Working on it
    I did get the 135 mm rods. Also, the block has been bored over to 2.8 liters (84.5 mm), should I consider the .82? Ultimately I want as much usable power as possible, in the least amount of time.
    Apr 2006
    Minnesota eh?
    86 325es
    Unless you put an M52 crank in it as well its not 2.8 liters. I was asking what pistons you got, I know the rods you have are 135mm. Wiseco has a part number for pistons to match 135mm rods, and for 140mm rods.
    Aug 2015
    Crystal Lake, IL
    1996 BMW 328i Sedan
    Aw dang it, I have a 2.8L and a 0.63 into a 3” exhaust.
    Am I screwed? Or is this going to be a jumpy little turbo?
    Oct 2018
    Eugene
    Working on it
    That totally makes sense about the displacement. Also, my pistons are model number ke115m845.
    I see that there is a .68 t4 size option available. I would be willing to purchase a t4 manifold if that would be the ideal choice.
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by E30round2 View Post
    Those are the correct pistons, just checking. No need for a t4 for what your doing. Open T3 will be perfect.
    Quote Originally Posted by SilburE36 View Post
    Don’t fret about it, it’s not that big a deal.
    Oct 2018
    Eugene
    Working on it
    Some guy, do you have a recommendation on piston rings gaps?
    Apr 2006
    Minnesota eh?
    86 325es
    .018” top, .021 2nd
    Oct 2018
    Eugene
    Working on it
    Thanks a lot for your help. I have noticed how involved you are in the forum, and would just like to let you know that it means a lot that you take your time to help a new guy like me. I won't ramble on and on, but I did want to take a second and let you know that this internet stranger really appreciates your contributions.
    Apr 2006
    Minnesota eh?
    86 325es
    No problem, just paying it forward
    Oct 2018
    Eugene
    Working on it
    So, six plus months later my engine is finally assembled and installed. What a journey. It turns out that the RSI manifold I purchased will fit either a t3 or a t4 turbo housing. My options are t3 .63 A/R or t4 .68 A/R. I'm sure the difference will be minimal, but which would you recommend? I'm sure I'm overthinking it, but I've never done anything like this before. Thanks in advance.
  1. Borg Warner S200
    By fhpchris in forum Race Cars & Track Parts
    Last Post: 05-08-2008, 12:20 AM
  2. Borg warner oxygen sensor
    By BTLAMAR in forum 1991 - 1999 (E36)
    Last Post: 03-20-2007, 07:45 PM
  3. Borg Warner/3k/hoslet T04B H3 Turbo
    By e34m535t in forum Engines, Performance Parts & Software
    Last Post: 03-13-2007, 11:50 PM
  4. What's your opinions on Borg Warner turbos?
    By CeeP in forum Forced Induction
    Last Post: 10-15-2006, 07:47 AM
  5. Borg-Warner K3 turbo, 3.5" HFM, 3.0" HFM
    By northeaste36 in forum Race Cars & Track Parts
    Last Post: 01-09-2006, 10:31 PM
