Results 1 to 6 of 6
Thread: 2008 E93 - Truck Latch will not open - makes Noise but stays locked
    Sep 2017
    Key Bicayane
    e93
    Hello,
    So here is the situation. I am new to the BMW last year, and so far have been earning my stripes:
    1) Sparkplugs / Coils
    2) Rewired Headlights that were cracking
    3) Rewired the Fan Blower that was overheating the ground
    4) Replaced the Starter
    So the latest issue (And the above I don't consider bad for a car 10+ years old) is that the trunk latch whirrs and makes a sound like it is decoupling when activated, then does not open.
    So - Can I force the latch to open with the emergency Trunk Release to access it and check it out? I can access when the top is closing / opening from the lid. Or is there some place I should start with Diagnosis. As I said - there appears to be action in the release, but not sure if there is a trick that these sometimes stick etc.
    Any and all help is appreciated.
    Thanks!
    Steve
    Sep 2017
    Key Bicayane
    e93
    Does anyone have the link to the technical pages on the trunk assembly- to get started?
    Steve
    May 2017
    Ontario, Canada
    335i E93 N54
    On my 2008 335i E93;
    I pop the key out of my FOB, put it in the trunk key-hole, then turn.
    This works even with the battery disconnected. (thankfully)
    Sep 2017
    Key Bicayane
    e93
    Woo Hoo!
    It worked - so at least now I have a functioning trunk until I have time to trouble shoot the AUTO latch mechanism
    Codes2 - did yours also fail in a similar manner?
    I would like to be able to understand how to test it while the trunk is open, so that I can set the switches and watch it function (or not function)
    Steve
    May 2017
    Ontario, Canada
    335i E93 N54
    Quote Originally Posted by sesproul View Post
    Woo Hoo!
    Steve
    Sorry sesproul,
    In my instance, I willfully disconnected the battery for other reasons. Then when the trunk closed, I started hunting for options!
    Sep 2017
    Key Bicayane
    e93
    Is there a guide / entry in the manual that someone can point to where the latch is adjusted, now that I can get it open with the key?
  1. E93 cabrio glove box not opening.
    By OldmanofYork in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 09-10-2018, 05:01 PM
  2. 2008 328i Hood will not open
    By Steve O in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 11-18-2015, 10:51 PM
  3. Seat Belt Latch Not Opening
    By crb635 in forum 1976 - 1989 (E24)
    Last Post: 12-04-2014, 07:47 PM
  4. Replies: 5
    Last Post: 04-02-2013, 02:13 AM
  5. Hood latch pops the hood, but it's not opening. Advice?
    By aa240sx in forum 1996 - 2003 (E39)
    Last Post: 03-11-2010, 01:42 PM
