Results 1 to 6 of 6
Thread: Intermittent E46 snottiness
    Boise, ID
    2003 325i (E46 SAL)
    2003 BMW 325i Saloon E46 / M54 Engine
    Last spring (2018) I
    replaced my O2 Sensors
    rebuilt the DISA valve (vane and vacuum diaphram)
    cleaned out the idle control valve
    replaced split intake runners
    The car passed DEQ and has been running without problem(s) for over 10 months now.
    The "Check Engine" light came on around the beginning of February this year. My Peake tool sez' the O2 sensors are hitting their limits and all six cylinders show misfires.
    The issue comes and goes, it's not constant. The car won't idle when the problem presents itself. The car will start but dies as soon as I let up on the gas.
    And then the problem will disappear, the CEL will turn itself off and everything will go back to working like it always has.
    I don't know where to start looking. Intermittent DISA valve? Failing Idle Control valve?
    Peake R5/FCX(3) Code Readout
    19 Code Table
    E4 O2 Sensor Adaption Limit, Cyl #4-6
    E3 O2 Sensor Adaption Limit, Cyl #1-3
    CB O2 Sensor Control Limit, Cyl #4-6
    CA O2 Sensor Control Limit, Cyl #1-3
    F0 Misfire, Cyl #3
    EE Misfire, Cyl #1
    F2 Misfire, Cyl #5
    F3 Misfire, Cyl #6
    F1 Misfire, Cyl #4
    EF Misfire, Cyl #2
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    How old is the fuel pump? When was the fuel filter last changed? The filter contains the fuel pressure regulator. The fuel pressure has to be at least 50psi under all engine speeds and loads.
    What causes misfires:
    - old/wrong spark plugs
    - bad coil
    - crapped up/dirty/bad fuel injector
    - failing fuel pump
    - blocked/bad fuel filter
    - bad fuel pressure regulator
    - poor compression
    - bad crankshaft position sensor
    - mechanical issues such as a burned valve.
    The first step in properly diagnosing a problem is to scsn the engine computer (DME) with a proper scan tool. The Peake tool is ancient history.
    Boise, ID
    2003 325i (E46 SAL)
    MarcoZandrini
    I also replaced the fuel filter last spring while I was doing the O2 sensors.
    I'd buy the 'fuel' scenario if the car was snotty under acceleration or cruise but it's only snotty at idle.
    I'm leaning more towards an Idle Control Valve that intermittently gets stuck in the wide open position.
    I'd really rather it be something else 'cause , as you know, it's buried so deep in the intake. Sigh!
    What do you consider 'a proper scan tool'?
    Any software scan tools worth a hoot (coupled with which ELM327 Adapter actually works)?
    Jan 2017
    USA
    E21, E46
    Your codes say otherwise. Freeze frame data would be interesting. You can clean your ICV with ICV cleaner and brake kleen. Remove it from the intake, clean it and then reinstall.
    It will take you about an hour.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Get the OBDFusion app for your smartphone or tablet. Then head over to E46Fanatics and search for threads that mention OBDFusion and in which jfoj has commented. He’s the guru.
    The O2 sensor codes are saying that the fuel/air mixture is way out of whack.
    Jan 2016
    Ca
    2001 525it
    I have never had to replace a idle control valve on an e46, I've seen lean faults for fuel pumps acting up
  1. problem starting car (intermittent) - e46
    By jboyne in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-06-2009, 05:13 PM
  2. intermittent electrical problems in E46 M3?
    By SDbboy in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 09-16-2008, 12:58 PM
  3. Replies: 9
    Last Post: 04-30-2007, 07:09 PM
  4. Intermittent Alarm e46
    By flyn4cents in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 08-30-2006, 09:59 PM
  5. e46 braking / suspension issue ( intermittant shaking)
    By zanick77 in forum 1999 - 2006 (E46)
    Last Post: 10-29-2004, 01:37 PM
