Results 1 to 9 of 9
Thread: Big brake question
    Jan 2019
    Connecticut
    E92, E46, E36
    Big brake question
    Has anyone here run a bbk with style 5's? If so were there clearance issues with wheel diameter or back spacing?
    Sent from my SM-G960U using Tapatalk
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I would think that the ET20 of Style 5 is spacing the wheel out further and adding clearance for BBK just like a spacer on ET41 stock wheels. This comment is for E39 spec Style 5 on E36.
    Mar 2011
    Seoul, phoenix, missoula
    galant vr4 S13
    You need to get the brake caliper position before an accurate answer can be provided. Depending on the BBK you're going to use the caliper position will change based on rotor size and caliper design. I know Alex (sales@brewedmotorsports.com) has always helped me out with brake kits that fit under a particular wheel, i'm sure he would have more than a couple good options for the style 5's on an E36.
    Jun 2005
    New England
    I’d be interested in the wheel choice as well. My ST40 F+R will fit under my summer Apex ARC8 17x9 ET42 with 12 mm spacers up front and no rear spacer, but require a 25mm front and 15 mm rear spacer when used with my winter 17x17.5 Contours that are ET41. The difference is due to the inside contour of the wheel rims.
    Jan 2019
    Connecticut
    E92, E46, E36
    Thanks tunermt, I'll reach out to him and see what he sugguests and I'll post what ever info I find out so maybe it will help others
    The Netherlands
    DE-spec E36 328i/M3 cab
    When I had my BBK I needed 20mm spacers up front on my BBS RS wheel.
    Problem with the RS vs style 5's is the smaller center, which makes the circumference of the bolts closer to the center i.e. closer to the caliper. Otherwise 14mm would have cleared my wheels.
    IG:
    Mar 2011
    galant vr4 S13
    Quote Originally Posted by Ctwide3project View Post
    He's always seems more than happy to help out, enjoy the project can't wait to see the BBK behind those wheels
    Jan 2019
    Connecticut
    E92, E46, E36
    I'll be sure to post pictures and share them along the way!
    Mar 2011
    galant vr4 S13
    Oh yes you know we all want to see the pics of your Big Brakes behind those wheels!
  1. 528i touring Big brake questions???HELP
    By draco02 in forum 1996 - 2003 (E39)
    Last Post: 11-16-2011, 12:47 AM
  2. E36 Big brake question
    By GMW364i in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 07-12-2007, 01:54 AM
  3. Big Brakes Question.
    By CrazyINP in forum 1992 - 1999 M3 (E36)
    Last Post: 10-18-2005, 06:47 AM
  4. Big Brake Question?
    By bennetts22 in forum 1987 - 1991 M3 (E30)
    Last Post: 07-24-2005, 10:25 AM
  5. Big brake question --- anyone with a big brake kit (UUC)??
    By bmw m3 s50 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-03-2004, 05:59 PM
