Results 1 to 6 of 6
Thread: Relay k4 86 325es
    Aug 2016
    EastCoast
    2001 740i
    Relay k4 86 325es
    Can I buy this relay locally or is it bmw specific my current one is burnt out? I知 having a hard time finding one new
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    Put the numbers on it into Google and it will show if you can buy at any local stores down the search page list.
    Which relay is that?
    Aug 2016
    EastCoast
    2001 740i
    Quote Originally Posted by superj View Post
    It痴 for Low beams I ordered the part I知
    currently in the process trying to figure out why my low beams only work if the high are on as well
    Dec 2005
    No e30s, again :(
    Hmm, switch is good?
    No e30s again.
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    Sealed beams? Both your outboard low beams are possibly burned out. Sealed beam low beams have 2 filaments; low & high. The low lights in low beam and the high in high beam. It's basically 2 lights in one package. The low filament can burn out and still leave the high functional. Have you checked for voltage at the connector? It's the yellow/white or yellow/blue (depending on side) wire. Make sure you check with ignition and switch on.
    "Howdy, Folks!"
    Aug 2016
    EastCoast
    2001 740i
    Quote Originally Posted by richardodn View Post
    Okay I値l take a look at it tomorrow and check back in.
  1. Parting Out 86 325e...
    By David90325is in forum BMW Parts For Sale
    Last Post: 06-18-2002, 12:01 PM
  2. 86 325e - What is this???
    By pjgonwa in forum 1983 - 1991 (E30)
    Last Post: 06-08-2002, 05:03 PM
  3. Coolant light 86 325es
    By joe325es in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-11-2002, 11:19 PM
  4. 86 325e - What is this???
    By pjgonwa in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-23-2002, 09:44 PM
  5. 86 325es Odometer Fix?
    By huberc in forum 1983 - 1991 (E30)
    Last Post: 08-01-2001, 09:22 PM
