SOLD
I got these Depo headlights new from DaytonaM3 last summer and have only put about 1,000 miles on them (installed for around three months). DaytonaM3 custom builds them to customer spec using all new parts, which includes Depo headlights, FXR projectors, HID bulbs, ballasts, and all hardware.
The low beam bulbs are 4500k temp (bright white with a hint of blue), and clear LaminX has been applied to the glass lenses. They come with Morimoto 35W ballasts, making the setup plug and play. The inner low beam glass lenses have been cut to allow the HID lights to function to their full potential.
The high beams are set up so that when the low beams are off, only the inner, halogen lights illuminate. When the low beams are on, both the inner and outer lights will function as high beams. If quad high beams are not desired, a quick and easy modification can be done so only the halogen lights work as high beams. They can easily be wired for city lights as well by tapping a wire into the corner lights (bulbs are already installed).
The light output is noticeably better than OE E46, E9X, and F3X xenon headlights. There are no angel eyes or other mods that take away from the OE look of the headlights.
The upper corner light mounts broke off on both the left and right headlights, and one of the lower headlight mounting tabs is partially cracked but still attached to the housing. The corner lights can still be installed securely.
Photos of the headlights, as well as examples of the output and city lights are provided in the link below.
https://drive.google.com/open?id=0By...TIyNUVkSkRRRGs
$500 shipped to the contiguous US states, plus 3% PayPal fee
Pick up in Katy, TX is also an option.
If interested, please send me a PM.
$400 shipped?
