SOLD
I'm selling my extra trunk that has an eBay GT wing mounted to it. The wing arrived damaged from Europe and was repaired, then painted Cosmos Black along with the trunk. The lower portion of the wing is taped onto the trunk using double sided 3M automotive tape. Mounting holes were drilled onto the trunk lid, with access holes underneath. All hardware to use the wing with and without risers are included. There is no sag in both the low and high positions. My paint guy did his best to eliminate the waviness of the fiberglass, but those are still visible.
**The trunk lid will not come with any other parts. They will need to be swapped over from your current trunk or sourced separately.
Pick up in Katy, TX. I may be able to bring the trunk to Austin as well.
I can remove the wing from the trunk to allow for shipping, but the price will remain the same, as I will be giving away the trunk.
$250
Still available?
