Cluster comes on then off with no signal idicator or back light. Signals do work from outside . Just not cluster.
Sent from my HTC6545LVW using Tapatalk
Google “BMW E46 hidden OBC functions.” There’s a test that exercises the cluster. This will tell you whether the issue is in the cluster or not.
Cluster test revealed everything is operational
I’m, that’s good news. How old is the battery? Test #7 shows the voltages as seen by the engine computer (DME). Check and report back the voltages when the:
- ignition in the run position with the engine off
- engine idling
- engine revving at 2000rpm.
Why? Whacky voltages cause whacky issues.
Check fuses
