Hey guys,
So i finished throwing an s52 in my 325i and it seems like I have 2 lingering problems. I have a p1145 code which directs me to the 3/2 valve or fuel control valve (whatever you would like to call it), I was planning on replacing that, but at the same time I have a misfire going on too. I pulled all the plugs and only cylinder 2 looked fouled (maybe 50 miles on them), clearly running rich in that cylinder. Swapped the plug to a new one (the one I took out was basically brand new) and it's still doing it, going to grab another coil pack to throw in as well.
Would a bad coil pack be causing a cylinder to be running rich or is there something else going on? And is it possible that the 3/2 valve would be causing the misfire? The fact that it was a single cylinder makes me think it's not the 3/2 valve causing it. Any input?
I would think that if the 3/2 valve or FPR was bad, it would do it on all the cylinders, thus giving you a rich condition on all the cylinder. So the next thought is after you swapped/tested the coil, and still getting a fouled plug is to look at the injector.
Darin
Current:
Past:
79 525 euro Green/Green RIP
M-Flight Member
Note that a single injector running rich, or lean, on one bank will cause the other 2 to run the opposite direction, because the DME can only see three cylinders at a time.
I'd recommend sending your injectors off to RC Injection, for complete testing, service, cleaning, and "blueprinting"....for $25 per injector.
Chris Powell
BMWCCA 274412
Perfect, thank you guys. Gonna swap the coil around and see if it follows then if it still happens go up to the injector. Will report back!
