Hi guys, just put a m52 in my z3 which was not a simple plug and play swap, i basically got it running using the wiring harness for the engine from an e36
does anyone know how i can get the abs and airbags lights working in the cluster?
do they run off their own ecu's or are they linked to the engine ecu?
thanks
You are very likely going to need some wiring diagrams to figure that one out. I have had great luck with ALLDATA and would start there.
