Results 1 to 12 of 12
Thread: I made a thing? CCV
    Sep 2008
    selah WA
    1996 m3
    I made a thing? CCV
    Not a mind blowing part but thought it worked out well. 3D printed a slip in ccv fitting with dual o ring to connect 5/8” hose. Strong enough to wrestle on the hose and clamp without issue. Cost was rather low as well. I can post the files if anyone would be interested.
    Jan 2018
    Arizona
    93 325is
    Think this has been made already but good work nonetheless
    Jul 2011
    Bay Area, California
    M3 w/Gt35r
    I'm interested!
    Also, what catch can is that?
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Looks clean. I have a hose clamped on top of the factory valve cover neck. The bigger issue is the size of the internal port, which is much smaller than the exterior neck. A few have opened it up but there is not enough material so you have to do more serious modification. Chikinhed posted details years ago.
    Nov 2013
    VA
    E36
    Good way to put a 3d printer to use. My friend made camshaft timing blocks with his not too long ago. Because of the small internal port mentioned above, a lot of people have drilled two ports in valve cover for better pressure relief. The factory port is then blocked off.
    Sep 2008
    selah WA
    1996 m3
    Quote Originally Posted by bmw328m52 View Post
    Correct the interior is smaller. I will probably reprint later after I drill out the ccv port to enlarge it. I’ve designed a bracket to hold the SAP near the power steering reservoir. So I was not so concerned with ID as there will eventually be an assisted vacuum on it.
    Aug 2015
    Crystal Lake, IL
    1996 BMW 328i Sedan
    I made a thing? CCV
    I welded a short piece of 7/8” aluminum rod to a -10AN fitting, then used the hole in the fitting as a guide to drill out the rod.
    I then JB welded that sucker into the valve cover fitting. Saw some guy on revlimited do that.
    May 2013
    Las Vegas, NV
    UFO
    Looks great. Would love the files. I'm trying to figure out a solution for this right now.
    CURRENT: LimeRockParkEdition E92 M3 - BSM/Silverstone E70 X5M - AW/Dove E36 M3
    PAST: Techno/Dove E36 M3 - Techno/Dove E36 M3 - LSB/Black E46 M3
    Sep 2008
    selah WA
    1996 m3
    Quote Originally Posted by VLT View Post
    If you pm me your email I’ll send the stl file.
    Virginia
    97' m52 turbo
    Looks great
    Sent from my SM-G960U using Tapatalk
    Nov 2016
    Sweden
    93 325i Turbo, 09 535D
    Nice work, please send me the file. (im sending my email through PM)
    What material did you use? Im going to let a friend print it for me
    Regards
    Sep 2008
    selah WA
    1996 m3
    Quote Originally Posted by mackiiN View Post
    Regards
    I printed in sla for accuracy an quality. Could print in abs without issue. Pla may warp with heat.
  1. Made some things tonight
    By gelb3 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-02-2008, 06:31 PM
  2. They made me do things I regret now.
    By Makr in forum Southwestern - US
    Last Post: 02-08-2005, 12:39 AM
  3. Is this things made out of gold?
    By 300ZXNA in forum 1992 - 1999 M3 (E36)
    Last Post: 01-14-2005, 02:32 AM
  4. coolest thing youve ever made?
    By cS in forum Off-Topic
    Last Post: 05-11-2003, 02:04 AM
