Results 1 to 19 of 19
Thread: 5 speed short for 82 320i Auto conversion
    Dec 2016
    Atlanta Ga
    98 M3 Sedan, 82 320i
    Found a 5 speed short part # 240 00 266 90 255 for my 82 320i Auto conversion for a reasonable price. It comes with cross member and flywheel.
    If I get my driveshaft cut and balanced what am I missing- pedal box, shift selector,interior trim, new clutch, slave cylinder and line to tranny ?
    Dec 2016
    Atlanta Ga
    This is what i got. Tranny flywheel, cross member, clutch and slave cylinder with the short line attached supposedly pulled from running car with 80k.
    Mar 2016
    Bentonville, AR USA
    91 318is - 83 320is
    Does the trans have the shift fork? Is that an e30 or e21 trans?
    Pressure plate and throwout bearing
    Shifter console (sheet metal housing that bolts to trans)
    Clutch master
    Can't remember if you just cut the nub on the fluid reservoir that feeds the clutch master, or if you have to get a manual specific one, but worth looking into. There's a hard line that runs up to a short soft line connection at that reservoir as well.
    91 318is
    83 320is
    Dec 2016
    Atlanta Ga
    Yes it has the shift fork and the clutch parts they all look good. Here is a picture of the speedometer cable on bottom left near the part number
    Mar 2016
    Bentonville, AR USA
    91 318is - 83 320is
    Also make sure you replace the shift fork plastic nub. They have aftermarket ones that are bronze or stainless, but stock is plastic. With the trans already out, now is the time to do so.
    91 318is
    83 320is
    Houston, Tx
    '78 320i
    I have a shift plate/arm if you need it. Id let it go for cheap...
    Dec 2016
    Atlanta Ga
    Is that the whole assembly with the shifter included?
    Houston, Tx
    '78 320i
    No it is just the plate (realoem calls it an arm). Check out realoem. I am using the shifter in my current car.
    You should look to see if a double shear selector rod (DSSR) could work for you as well. Really improves the shift feel. Garagistic has quite a few sizes, maybe one works for the e21
    Dec 2016
    Atlanta Ga
    Ok Looking at the diagram I now see the parts involved. I am filling my parts list as time allows. I'll check back with you.
    Dec 2016
    Atlanta Ga
    240 back.jpgWhere is the plastic nub?
    Mar 2016
    Bentonville, AR USA
    91 318is - 83 320is
    Unclip the spring to your left and it's under the shift fork.
    91 318is
    83 320is
    Dec 2016
    Atlanta Ga
    Question is their differences in the shift assembly among the various trannys that fit the e21? Still collecting parts for my 5sp swap.
    3hp22 with 3.64 dif at hwy speed.
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Cool
    According to realoem there is, I have a pair of Getrag 245 5 sp both with complete shift assemblies and platform, No Getrag 240 though so you'll need to confirm.
    From Realoem
    Selector shift rod 9/79-9/82 is L=151mm Getrag 245
    Selector shift rod 10/82- is L=288mm and shows for E30 as well, assumption Getrag 240.
    Shifting Arm or Platform is different too in BMW Numbers
    25111208464 Getrag 245
    25111220316 Getrag 240--E30 as well
    Getrag 245 and 240's are different in length and different in length of drive shaft, Guibo is different as well 8 holes and 6 holes.
    Randy
    Dec 2016
    Atlanta Ga
    Good to know I'll search for early e30 Getrag 240/5 parts too.
    Dec 2016
    Atlanta Ga
    Took your advice I found these on ebay from a 85 e30 318. Ad read 82-88 e30 m10 1.8L.I looked at real OEM and the part numbers are the same for both models 85 318i and 11/82 320i.
    Price was reasonable
    Nov 2007
    Cool
    Neat
    Randy
    Dec 2016
    Atlanta Ga
    I hooked up what i got so far and it shifts thru all the gear. I'm missing some plastic parts - lower cup,spring, clips and few odds and ends
    I appears to be the correct parts. The rod has a short end I'm assuming the transmission coupler side and long end shifter side. How many plastic spacers do i need for the shifter rod? I'm not that familiar so learning as I go.
    Nov 2007
    Cool
    As many as it takes to take the slack out when the end has its clip or snap ring inserted ,, I used one on each end and it was snug.
    Randy
    Dec 2016
    Atlanta Ga
    I'll pick up more than 4 #6 plastic washers might need 6-8. the selector rod shifter side is a bigger end. FCP has mostly everything.
    bmw E21 240:5 shifter_1.png
  1. Short Circuits on my 82 320i...
    By Beater82e21 in forum 1975 - 1983 (E21)
    Last Post: 03-27-2013, 12:44 AM
  2. 82 320i 5 speed
    By ilikepretzels2 in forum 1975 - 1983 (E21)
    Last Post: 09-05-2009, 03:35 PM
  3. WTB: e36 M3 ZF 5 speed for auto conversion
    By 95RedBMWe36M50 in forum BMW Parts Wanted sponsored by Bavarian Auto Recycling
    Last Post: 04-16-2007, 04:12 PM
  4. FS: 81 320i auto- daily driver/PARTS/ 5-speed canidate
    By Crusty320 in forum 1975 - 1983 (E21)
    Last Post: 10-17-2006, 03:24 PM
  5. WTB: 5-speed tranny for 635 auto conversion
    By exploding head in forum BMW Parts Wanted sponsored by Bavarian Auto Recycling
    Last Post: 04-29-2006, 10:01 AM
