Results 1 to 21 of 21
Thread: Where to get silicone intake boots?
    Dec 2016
    Los Angeles, California
    2002 E46 BMW 325i
    Sorry if this has been asked before but I couldn't find much for E46s. I remember mishimoto used to make silicone intake boots but they stopped producing those. Would I have to measure my throttle body and just get a generic silicone boot? I don't like how the M54 manifold placed the throttle body so low but I don't know if that'll be an issue since you can make the intercooler piping work with how you need it to be.
    Mar 2016
    Australia
    e30 318i, 135i
    I just bought mishimoto a couple of months ago, so they can still be found.
    As mentioned in other threads, you're not likely to find much for e46s here, best to stick to e46fanatics over there.
    Dec 2016
    2002 E46 BMW 325i
    Quote Originally Posted by ba114 View Post
    I know but I find bimmerforums to include a lot more experienced members with forced induction. I was hoping maybe someone may know where I can even get it custom made
    Jul 2011
    Bay Area, California
    M3 w/Gt35r
    Maybe shoot NickG of Technique Tuning an email. He might still be selling turbo kits/parts.
    Dec 2016
    2002 E46 BMW 325i
    Quote Originally Posted by IR M5 View Post
    This is why I prefer bimmerforums for FI
    I'll shoot him a message
    Dec 2016
    2002 E46 BMW 325i
    https://drive.google.com/open?id=17p...fHEg85OLGUnEad
    I ended up getting this off ebay and it worked pretty well https://www.ebay.com/itm/3-inch-76-m...53.m2749.l2649
    I have a quick question though. Is the f-connector able to see boost? I was planning on just making a small hole in the boot and jb-welding the f-connector inside it.
    Nov 2008
    Indiana
    97' 328is, 07' Titan
    You can't use JB weld on a flexible silicone boot. For one, it's flexible... for another silicone doesn't stick to very much.
    General safe rule is if it doesn't connect after the throttle body where there's vacuum then it shouldn't see boost. The IAC only slightly breaks the rule since it connects before AND after the throttle body and should be left in that configuration or else it will be a boost leak.
    1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
    Dec 2016
    2002 E46 BMW 325i
    Quote Originally Posted by somebody5788 View Post
    Thanks for the reply. I will be deleting the ICV as I've been told many times that it can get stuck open under boost. This silicone boot isn't super flexible but I understand the point you're making. I will try to find something that will stick.
    Will the check valve that I'm looking for be one for vacuum to air or something? I'm not sure what the term is if there isn't vacuum and it isn't boost. Atmospheric pressure?
    Dec 2016
    2002 E46 BMW 325i
    Mar 2016
    Australia
    e30 318i, 135i
    just plug the F connector. Find another manifold source for the line to the FPR.
    Dec 2016
    2002 E46 BMW 325i
    It isn't just the fpr, the brake booster connects to it too
    Nov 2008
    Indiana
    Quote Originally Posted by armenh7 View Post
    I don't know who told you they get stuck open from boost but it's totally false I don't suggest removing it. The valve will have more pressure on it at idle due to the vacuum on one side and atmospheric pressure on the other that it's more like running 20 or more psi at idle and when in boost the pressure is even on both sides of it so it's like running nothing.
    Dec 2016
    2002 E46 BMW 325i
    Ah I see. I was told by two fellow boosted E46 owners and Alexander Hopwood from Hopwood motorsports. I already figured out how to do my ICV delete so that really isn't a big deal anymore. My question remains for the check valve. I think this may work http://www.siliconeintakes.com/liqui...d--p-9582.html
    Mar 2016
    Australia
    e30 318i, 135i
    there's no issues with plugging it. Have done so myself
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    If you want silicone that is aesthetically pleasing, check out this UK vendor. https://www.performancesiliconehoses...-hoses-9-c.asp
    Fairly expensive, but worth it in my opinion.
    Dec 2016
    2002 E46 BMW 325i
    Here's what I ended up coming up with and in theory it should work out well - The bungs are a makeshift F-connector for the fuel filter and brake booster hoses
    https://forum.e46fanatics.com/attachment.php?attachmentid=771739&d=1554313172
    Nov 2008
    Indiana
    You could run into stalling issues without it
    Dec 2016
    2002 E46 BMW 325i
    If the DME isn't tuned for it, right?
    Here's what my reference point is https://www.ms4x.net/index.php?title...l_Valve_Delete
    Nov 2008
    Indiana
    Tuning for it is a bandage. It "works" but it's not the correct way to do it.
    Dec 2016
    2002 E46 BMW 325i
    You give out great advice, so I will be listening to you. It seems like I'll have to do something similar to how I did for my f connectors? Have a bung welded on and find a fitting that would be the right size for the icv. It would have to be silicone, right?
    Dec 2016
    2002 E46 BMW 325i
    Here's the new setup:
    https://drive.google.com/file/d/1_tH...ew?usp=sharing
    The dual sided fitting is the new "F-connector" and the other barb is for the ICV
  1. Bimmerworld silicone intake boot - 3.5"
    By jmitro in forum Engines, Performance Parts & Software
    Last Post: 11-10-2008, 01:26 PM
  2. FS: Bimmerworld 3.5" Silicon Intake Boot + 3.5" HFM + Custom Intake!!
    By BimmaDave in forum Engines, Performance Parts & Software
    Last Post: 10-24-2008, 12:35 PM
  3. Bimmerworld Samco Silicone Intake Boot
    By clex2 in forum 1991 - 1999 (E36)
    Last Post: 07-25-2007, 07:06 PM
  4. FS SAMCO Silicone Intake Boot
    By m52 E30 in forum Race Cars & Track Parts
    Last Post: 03-19-2007, 11:14 PM
  5. edge silicon intake boot???
    By hnoppenberger in forum 1992 - 1999 M3 (E36)
    Last Post: 06-09-2006, 02:51 PM
