Results 1 to 11 of 11
Thread: Noob... Transfer case fluid change??
    Feb 2012
    Houston Texas
    2005 BMW X3 3.0i
    Wanting to do my transfer case fluid swap. But I heard that the adaptation needs to be reset? I don't have a scanner other than just a obd. Will it make a difference or would I have to take to the "Stealer" to have it done?? Hopefully someone on here done it before
    Sent from my moto g(6) play using Tapatalk
    Feb 2012
    Houston Texas
    2005 BMW X3 3.0i
    Quote Originally Posted by rene0900 View Post
    2005 BMW X3 3.0i
    Jul 2011
    Binghamton, ny
    2006 X3, 95 TSI AWD
    You would need to download some of the dealer software floating around the internet. I think INPA can do it. It was difficult for me to get running but once it's running it's easy to use. I have changed my transfer case fluid without resetting and personally didnt have any problems... (insert disclaimer here) I eventually did reset them anyway.
    Feb 2012
    Houston Texas
    2005 BMW X3 3.0i
    Quote Originally Posted by Stephen95tsiawd View Post
    Guessing I need a fancy laptop and obd cable
    Jul 2011
    Binghamton, ny
    2006 X3, 95 TSI AWD
    What's funny is you actually need an unfancy laptop and a chinese made bmw usb obd cable that's very cheap.
    Feb 2012
    Houston Texas
    2005 BMW X3 3.0i
    Thanks bro. Bought the car used and don't know if the previous owner did anything maintenance. I have parts ordered for it, transmission filter and diff fluid. Going to chance it and use the max life ATF since none in town have the correct ATF fluid
    Apr 2014
    Renton, WA
    03 540i, 04 X3, 00 328i
    When I changed my fluid, I couldn't find anything in INPA to do the reset. I did the adaptations reset with DIS (GT1), which one can make work with the same cheap cable. However, the program itself is not quite so easy to install or run.
    Feb 2012
    Houston Texas
    2005 BMW X3 3.0i
    Thanks guys, could you tell me where I can find a good one? I checked eBay and Amazon and get flooded by different types. BMW sort of new to me, more experience with LR
    Oct 2016
    Las Vegas, NV
    2003 BMW 540i M Sport
    Like Stephen, I changed out the fluid without resetting adaptations about 6 weeks ago. My symptoms (kind of a shudder when coming to a stop, turning at slow speeds) went away. I'm only relaying my experience, not suggesting you do the same. Understand the manual says that you "will" screw up your transfer case unless you reset, but BMW also says their transmission fluid is good for the vehicle's lifetime. Apples and oranges, perhaps. If I had the right computer equipment, I would have reset. My (flawed) reasoning is that even though I drained the old stuff out, there is residual that will mix with the new and so it's not like I'm "shocking" the system with the viscosity difference. And after 6 weeks of varied driving with no issues, the adaptation is happening/has happened as it's supposed to.
    Feb 2012
    Houston Texas
    2005 BMW X3 3.0i
    Been driving it with out rest. Still driving good if not better. I did purchase a c310+ scan tool to reset, but gave me error message. Not sure I'd it's the device that's not good ( it does read pcodes) or there's something going on with communication with transfer case.
    Sent from my SM-A600P using Tapatalk
    May 2009
    Greenville, SC USA
    e39 M5 e39 540i6 e83 e53
    INPA doesn't do the adaptation reset for the transfer case. I bought the Foxwell NT520 to do my e83 T-Case. Good hand held scanner. Kind of a hand held INPA/DIS just not as intuitive. But well worth the $150! Better than going to the dealer..
  1. Transfer Case fluid change on 2011 328xi
    By NY Scotsman in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 10-26-2014, 11:27 PM
  2. Changes to expect from Transfer case fluid change?
    By Automaticftp in forum 1999 - 2006 (E46)
    Last Post: 11-03-2013, 11:16 AM
  3. Change transfer case fluid, computer reset needed by BMW?
    By Gee3 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 10-24-2012, 12:25 AM
  4. Replies: 8
    Last Post: 03-28-2011, 09:06 PM
  5. DIY - Changing X3 transfer case fluids
    By Borderline in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 05-28-2008, 01:18 AM
