Page 2 of 2 FirstFirst 12
Results 26 to 34 of 34
Thread: How important are subframe reinforcements?
  1. #26
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    I didn't mess with fender liners. I don't remember any reason to do that. I used the scissor jack to help with handling the subframe. I didn't disconnect any brake lines.
  2. #27
    Joppa, Md
    99 M Coupe,04 K1200rs
    no problems yet
    I've been axing my coupe for 40k and haven't seen any weld problems yet, very aggressive driving with big ,275/295 stickies on the back?, I did do a kluge fix on my subframe mounts years back, just screwed some big lag screws into the rubber mounts, eliminating the flex that may cause the problems being seen.I've been racing Bimmers for 25 yrs., I only seem to hurt motor/tranny mounts, and my clutch is going at 130 K, still fine for daily use, but slips in 2nd at full chat.
  3. #28
    Oct 2018
    West Bend, WI
    MRoadster,Tacoma,DR650
    Would it be possible for you to show a picture of your lag bolt reinforcement?
    Thanks.
  4. #29
    Renton, WA
    '02 BMW Z3 2.5
    The R.F. kit or equivalent (if there is one) is the way to go. Solve the real problem, not just the symptoms.
  5. #30
    Joppa, Md
    Quote Originally Posted by Tigershark48 View Post
    Thanks.
    I'm not to techie savvy, but you would just see the heads of the bolts seated on the bushings, not pretty or expensive, but very easy and fast, another kluge method is to drill out the rubber and fill area with JB-Weld,I also filled the support rubber in my csb with silicone to lessen strain on it.
  6. #31
    oskaloosa,ia
    '01 3.0 ZCoupe
    My coupe had 155k when I wrecked it. I had the car since 90k. I installed poly rsfb's as soon as I got the car. Ran countless autocrosses (>90), and ~40 track days/time trials with it. Not a single popped spotweld, and the diff mount was fine. Some cars need it, some don't. Keep an eye on it, if you start to see issues, get it done ASAP. If you don't, have fun! (poly RSFB's highly recommended)
  7. #32
    Oct 2018
    West Bend, WI
    Bionic,
    That’s a good testimonial. Which brand poly rsfb did you use?
  8. #33
    oskaloosa,ia
    '01 3.0 ZCoupe
    Started with powerflex, then went to condor speedshop's delrin. Powerflex is good for the street/auto-x/track days. No extra noise, smooth ride, etc. Once you bolt on the Hoosiers though, you can feel the poly squishing around, and delrin is what you need.
  9. #34
    SW Florida
    99-01 M Cpe & Rdts, X5M
    I didn't always work off a lift.
    Most of the work was done with the rear tires on a couple of 6 x 6s (about 2' long) I trust pressure treated wood more than any jack-stand.
    In order to swap s/f bushes, I had to resort to jack-stands.
  1. Rear subframe reinforcement
    By einhander in forum 1991 - 1999 (E36)
    Last Post: 02-02-2015, 01:51 PM
  2. Group Subframe Reinforcement in IL...
    By CwickzWannaBeM3 in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 09-16-2003, 04:09 PM
  3. If anyone is interested in rear subframe reinforcement welding for early e36's
    By ponq in forum Great Plains & Rocky Mountains - US
    Last Post: 09-03-2003, 01:58 PM
  4. whos else carry the Turner front subframe reinforcement plates?
    By LEVOC///MPower in forum 1992 - 1999 M3 (E36)
    Last Post: 09-11-2002, 10:14 AM
  5. m3 subframe reinforcment plates
    By hexbm in forum 1991 - 1999 (E36)
    Last Post: 03-04-2002, 01:06 PM
