Results 1 to 23 of 23
Thread: Rusty battery tray
    Nov 2018
    Sweden
    1996 850CI
    Rusty battery tray
    Hi!
    New to the forum and just bought a -96 850 that I'm restoring.
    The driver side battery tray is completely rusted through. It looks like the battery tray itself is a separate piece but welded to the body? Haven't been able to find anything online, is it available as spare part or used in other models?
    Sunny Cali,
    6.5 second 69 Camaro
    Actually i've seen worse, Try to sand it down and if it works out, Clean it and prime it with a acid resistant primer, They have No Nonsense spray sealer paints or similar you can use to, Get a can and spray a couple of coats, a hour in between coats, I installed Optima batteries and battery trays with no issues ever.
    Jan 2019
    Pittsburgh, Pennsylvania
    1972 2002tii
    right battery tray is available...
    Quote Originally Posted by buildit View Post
    Hi!
    Perhaps this will help!
    Page from our website.
    http://bimmer.com/bmw/showparts.do?m...90&hg=41&fg=25
    Item Nr 3 ($34.81). Must be welded in, but is readily available. BMW has 80 of them remaining. If this is a direction you wish to go, simply e mail me for more details. classicbmwparts@gmail.com I'm happy to help!
    Paul Wegweiser
    Lead Classic Specialist
    Maximillian Importing Company
    1-800-950-2002
    www.bimmer.com
    Dec 2013
    San Antonio
    850,76 2002 &530,84 633
    I was able to clean up the tray in my car and repaint it. Wasn't as bad as yours though.
    Nov 2018
    Sweden
    1996 850CI
    Quote Originally Posted by Wegweiser View Post
    Paul Wegweiser
    1-800-950-2002
    www.bimmer.com
    Thank you!
    I'm based in Sweden so shipping might be a bit much unless you have a European affiliate?
    Good to know that it is welded because the panel underneath is rusted as well so the tray will have to come out.
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    less than $30 in Norway... Schmeidmann is your spot
    www.schmiedmann.com/en/catn-ol?q=41128108482
    '91 850i 6sp (mint) (sold)
    Nov 2018
    Sweden
    1996 850CI
    Quote Originally Posted by cartoonz View Post
    Brilliant! Thank you!
    Sep 2010
    Finland
    bmw 850i M-tech
    Only right way to fix these issues is to remove the entire battery tray. It is spot welded and has to be drilled off. There is ALWAYS rust under the tray and if you don't remove it you wont be able to do it right. You only get the visible rust off but the problem stays. Actually, by looking at those pictures, there is a good change that you might need to replace some sheet metal also under the tray. Mine looked like yours and after removing the tray the sheet metal underneath was gone.
    after that, only use sealed agm batteries.
    Nov 2018
    Sweden
    1996 850CI
    Quote Originally Posted by mikae31 View Post
    Totally agree.
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Are these the same Left and Right?
    Sep 2008
    Santa Barbara
    Quote Originally Posted by rjjablo View Post
    yes
    Dec 2007
    Texas
    91-Dinan 850TT
    Here's a fancy option once you get the bottom replaced.
    Nov 2018
    Sweden
    1996 850CI
    I had a similar idea.
    Bought along with the batteries?
    Dec 2007
    Texas
    91-Dinan 850TT
    No, I need to look back and see where I got those mounts. That was many moons ago!
    Indianapolis, IN
    93 850Ci, 09 Caddy SRX
    Quote Originally Posted by TTTXGreg View Post
    Did you retain both batteries or go to single?
    1993 850Ci.....18 years & 165,000 miles and counting!
    San Jose CA
    1991 850i S70 6 speed
    Toomanyparts and I did this on my S70 car, which was not as severe as yours. This is what we used, please note both him and I are super anal, so we ended up taking everything carpet and trim out of the trunk and refinished the whole trunk.
    Ok this is what we used:
    Sand and clean obviously first
    Vacum
    repeat 1-20 times above
    Artlicious - Foam Paint Brush Value Pack (Two Inch - 20 Pack)
    POR-15 40101 Cleaner Degreaser - 1 gallon, put in a spray bottles
    POR-15 40201 Metal Prep - 1 gal, put in spray can and leave on for a bit. The direction is on the bottle. This removes the rust, does wonders.
    POR-15 45008 Gloss black Rust Preventive Paint - Pint, use brushed below to apply
    if you car is black you are good, but I got my cars color code and and ordered a Can Spray from Babarian and painted over it.
    I did this again recently for my 850ci1993 6 speed, BUT added a primer coat after Pro-15 Gloss black rust preventive paint, then Painted it (calypso red).
    This could be an all day or 3 days even if you want to do the whole trunk. Battery tray, all day even.
    Good luck.
    Alex Molavi
    Sep 2008
    Santa Barbara
    Only right way to fix these issues is to remove the entire battery tray. It is spot welded and has to be drilled off. There is ALWAYS rust under the tray and if you don't remove it you wont be able to do it right. You only get the visible rust off but the problem stays...
    Agree with this 100%
    Also, if you are replacing the tray, be sure to install the proper nutsert into the other hole so you can use H8/Group49 size batteries
    Jun 2012
    Mundelein, IL
    840Ci/6 528iT Europa TCS
    I believe the Por 15 product is made by the Eastwood Company. They have all kinds of products for painting over rust and then stopping the rust from progressing. They have a store an hour away and they have some of the neatest products and tools for car care, repair, and restoration. eastwood.com.
    San Jose CA
    Might be, I bought off of amazon. Cool project.
    I think treating the rust then going over it be the best option. Some might argue that paint is a anti rust protection. In my opinion since the rust has started it needs to be treated first.
    His tray is pretty bad shape so putting a new one in might make more sense.
    alex
    Quote Originally Posted by rjbaren View Post
    Dec 2007
    Texas
    91-Dinan 850TT
    Quote Originally Posted by TedBobo View Post
    Both- Some folks don't like the Optimas but I have had great service from mine several years.
    Sunny Cali,
    Me too on all my cars.
    Mar 2022
    Seaforth NSW Australia
    1991 850i
    Hi - saw this thread - I realise it was several years ago but I have the same issue with one of my battery trays - I need to get it off as am worried about what its like underneath. In reading what info is available I know that the tray is spot welded but can't quite work out how many & where they are as there's rust covering some of the "dips" which is where I have tried to drill.
    Any assistance would be very much appreciated - thank you Regards Rick
    Mar 2022
    1991 850i
  1. FS: Custom E46 Battery Tray for Lightweight Batteries
    By G.T. in forum BMW Parts For Sale
    Last Post: 10-09-2004, 09:40 PM
  2. AAH! Rust in the battery tray!
    By Gofast in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-17-2004, 09:55 PM
  3. Where can I get a 635csi battery tray and mounting bracket?
    By vinnymac in forum 1976 - 1989 (E24)
    Last Post: 08-08-2004, 07:12 PM
  4. Custom Battery Tray for OPTIMA Battery
    By RussM3 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 11-17-2003, 07:06 AM
  5. Matt... Battery tray ships tomorrow
    By TheNeek in forum 1975 - 1983 (E21)
    Last Post: 05-29-2003, 03:25 AM
