Results 1 to 6 of 6
Thread: Electrical and fuse gurus needed!
    Dec 2009
    Devon, UK
    '93 e31 850, '07 e60 525
    Ok in a previous post I mentioned I was having issues where fuse 19 (blower motor) was blowing as soon as the circuits were switched on. I've since removed the blower motor (that was fun), but found that it tests perfectly on the bench. With the motor disconnected the fuse still blows when the circuits are switched on, so this is leading me to the connection to the fuse box. The wiring diagram below is also pointing me towards the green/brown connection from the fuse to the relay k4. The relay is fine, and I'm figuring if the problem was pre-relay then fuse 21 would also blow? Really could do with some input from the clever people out there as I don't know the next step in investigation here as my electronics skills are only passable.
    If I had a penny for everytime someone commented on my poor fuel economy, I'd have enough to get it to the petrol station.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    F19 is downstream of the relay - which means nothing above it will cause it to blow. F19 only serves the blower motor via the GREEN/BROWN wire - unless something has been fiddled with. Of course, it could be something in the fusebox itself - and it is also possible that the ETK is wrong - I'll have another look at the other diagrams......
    My BMW Repair YouTube Channel
    Dec 2009
    Devon, UK
    Thanks Timm, I'm leaning towards something in the fusebox but not sure on the procedure for removing it as I can't find anything in the manuals. Any tips?
    May 2017
    Brisbane, QLD, Australia
    2011 Benz W212 E350
    Hi,
    I had a 30 amp fuse for the air conditioning on my 1995 840 blow repeatedly. I cant recall which fuse number it was but tracked it down to a faulty auxiliary fan in front of the radiator/condenser. Easy to check by removing the cover piece in front of the radiator (6 plastic 1/4 turn locks) & unplug the fan.
    Regards,
    Philip
    Brisbane, Australia.
    The other side of the planet, south of the Equator
    1969 BMW 2000 Mountain Green - Long gone in the 80's
    1976 BMW E12 520i Blue - Long gone in the early 90's
    1995 BMW E31 840ci Fjord Grey - Gone Thankfully (2018)
    2011 Mercedes W212 E350 Calcite White (The "armchair")
    Dec 2009
    Devon, UK
    I would imagine that was fuse 25 as that's a 30A linked to the aux fan. My aux fan works fine even with the blower motor disconnected but it's worth a shot before I dismantle the fuse box so cheers for the idea.
    As an aside can anyone comment on how difficult the fusebox is to remove? Its scary enough looking at all the wiring behind the centre console.
    Jun 2014
    Blue Springs MO
    M70 6sp. 540iT, 535is
    If you have blower motor removed, keep blower motor disconnected, and check resistance from blown fuse to vehicle's ground. See If you have any resistance. If you have some sort of resistance, then do "the wiggle wire harness test" while monitoring resistance results.
  1. EDC III problem - electrical gurus needed!
    By whiteghost1 in forum 1988 - 1994 (E32)
    Last Post: 05-02-2012, 02:23 AM
  2. Replies: 9
    Last Post: 09-20-2010, 09:18 AM
  3. Turn signal hell...electrics gurus needed!
    By biglittledog in forum 1983 - 1991 (E30)
    Last Post: 03-29-2007, 04:22 PM
  4. Wiring /Electrical Gurus - Need Some Taillight Wiring Help
    By ///MDex in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 01-22-2006, 05:43 PM
  5. Electrical gurus needed for advice
    By thisISlife in forum 1991 - 1999 (E36)
    Last Post: 07-29-2005, 06:47 PM
