Results 1 to 10 of 10
Thread: Will changing the pentosing filter make a difference?
    Iceland
    BMW 850
    I have been having this situation that when I brake on a turn my steering pump hesitates.
    I have been wondering if it would be connected with the pentosin filter in the canister or if there is another reason.
    Best reg
    Mar 2013
    netherlands
    850 CSI
    Could be, the system needs enough presure. Not likely btw unless really old oil and filters (in doubt, replace all.....drain from bottom of the car and back if you have 4 wheel steering). In total 2 or 3 filters. A clean system with new oil and filters will perform better.
    BMW 850 CSI march 1994 (EU spec), SOLD. https://www.classiccars-forsale.com/...94-bmw-850csi/
    BMW 850 CSI november 1994 (EU spec)
    Nottingham, UK
    E31, E36/7, E61
    ^ as above, plus check belt tension/tensioner.
    Iceland
    BMW 850
    Oil is old and I never changed the filters.
    Where are they located? I don’t have ahk
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Here's where it is and how to change it on an 840ci - it is the same as used on some 850ci's:
    https://www.meeknet.co.uk/e31/BMW_E3...ter_Change.htm
    My BMW Repair YouTube Channel
    Iceland
    BMW 850
    Thank you Timm.
    Will use that info
    Iceland
    BMW 850
    Timm. In your writeup I see only one filter. Are there any other ones?
    Mar 2013
    netherlands
    850 CSI
    850 (eu) has a brass filter housing in front (a metal filter you can clean). Under the car frontside of the engine.
    Iceland
    BMW 850
    Ok. Sounds perfect. Timm, the filter is the same on all models, right?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    I couldn't say for certain - I've only done the 840ci!
  1. Does a aftermarket cone filter make a difference on an M30?
    By Ricky318i in forum 1988 - 1996 (E34)
    Last Post: 07-20-2016, 03:55 PM
  2. Does changing sway bar bushings make a difference?
    By hrabieh in forum 1988 - 1994 (E32)
    Last Post: 03-28-2012, 08:08 AM
  3. Does 1/4" ride height change make big difference in cornering force/grip?
    By Master Apex in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 07-26-2010, 02:19 AM
  4. changed cabin filter and no difference
    By redlinedbimmer in forum 1991 - 1999 (E36)
    Last Post: 01-27-2008, 08:25 PM
  5. change the O2 sensor makes a BIG difference!
    By M3Jokster in forum 1992 - 1999 M3 (E36)
    Last Post: 03-21-2002, 10:31 AM
