Hi guys, I'm wondering if anyone can help me with this error code I have been getting:
[E] 00:35:46 An error occurred while reading "C:\NCSEXPER\WORK\FSW_PSW.TRC": Inconsistent data between parameter keywords "wert_11" and "wert_24" in function "ALC_KENNLIN_LWR_SENSOR_HI". Make sure chassis and module match those of the trace file.
It happens when I am trying to access the FRMFA.C10 module in NCSDummy (this module matches up with the module code in NCSExpert after I have changed the file from write to read). I have selected the original ECU as FRM in NCSExpert, aswell as selecting FRM when processing ECU.
I am trying to code this module for the e87 2005 120d. I am making sure that I have e89 selected in NCSExperty and NCSDummy as the e89 covers e87 chassis too.
The coding works for other modules, such as CAS, however I am trying to change features that I can only find in the FRM module, but it is not allowing me to do this.
Any help please?
hello tomjro
I am getting this one
when I go to GM5 C01,C02,C03,C04,C05,C06. I am getting this message
a RED( X )15:45:29 An error occurred while reading "C:\NCSEXPER\WORK\FSW_PSW.TRC": Unresolved parameter
keyword "500ms" in function "HUB_VERZOEGERUNG_FH_VORN". Make sure chassis and module match those of the trace file.
knowing I have had GM5 C01 & C06 working befor but now all of them are not ?
