So yeah, my blower motor just stopped working today. Everything has been fine till now. Now nothing. No fan all.
I've googled it of course. I've checked fuse 20 and 81 under the hood. I guess 2001 didn't have a K4 relay?? Tried hitting the dash.
Mainly I'm needing some input because I see evidence the 2000+ may be sightly different. Most write ups seem to be for early cars. So before I order up a motor and resistor, I'm looking for any ideas or experiences of any testing I can do.
Thanks for anything you can throw my way!!
2001 740iL "Silver Beauty"
1986 Porsche 951 "Silver Bullet"
1987 Porsche 944 NA Auto (rebuilding for my son's first car)
https://home.doonze.net/filepage.php <- BMW/Porsche doc's and files, work in progress
You've probably seen my thread on this. I've never looked to see if the wires are visible to test above the glove box or not on your year. It's most likely the resistor on the blower. You are correct there is not K4 relay so not sure the wire runs in the same area. Nothing I can really add beyond what's here:
https://www.bimmerforums.com/forum/s...eral-HVAC-info
@mayorchuck, Sorry, I bought a new house so this went on the back burner as I have been moving/improving/fixing for several straight months. But yes, I read your thread. Very helpful.
Things changed just after I made my last post. It stayed dead for about 2 days, then went full on mode at a set speed for about 5 weeks. Never turned off even with the car off. Now it's all over the place. On sometimes non-stop, off sometimes, then every once and awhile it works fine for a few hours. So I'm 100% positive it's my FSU. The other day, just as it was getting to be 80+ around here, it decided to be on a "off" kick. (started working about 2 hours later) but it's motivated me to move this up on the priority list. I was fine with always on, even after 4 days my battery was fine, but this off in the summer thing isn't going to fly. Ordering one now.
Thanks for the input!
Yes the work it takes to get to the fan and relay I just changed both. Then good for another 10 plus years.
I had the same kind of problem. Mine was just a bad motor brush which cost $5 to replace. I had ordered both items for replacement but just sent them back. Getting the dash out is not bad once you have done it. Just go slow and if it doesn't move look for another clip or bolt. When you get them all it just comes up and out.
01' 750il Chromeline
95 M3 LS swapped
07 M5 Manual
06' M5, Spartan wheels and a 507hp V10
00' 740il Dinan, CAI, Romulus exhaust, Stage 5 engine and transmission tune, 750 brakes, camber plates, strut tower brace. Sold
00' 323i wagon for daughter
03' 525i wagon for the wife, sold
98' 740i for the daughter, wrecked
92' 525i with over 200k, wrecked
02' R1200 CLC, hit by a bus and broken in half. That one made the news!
It's like herpes there is no cure but if treated properly you can live with it for the rest of your life
I got the blower/resistor in this week, however all car related stuff has gone on the back burner as I bought a new place and have been moving and getting the new place in shape that last couple of months. I finally just got the very last of my stuff moved, so it's back to cars soon! I'll report back with my results to add to the collective knowledge!
