I'm looking at a 2005 Z4 with a 3.0L and a 6 speed. Is it considered a 3.0SI?
Also what is the name of this color?
I own mostly junk. Except the Porsche, that's kind of cool.
All the motorcycles are trash which you can read about at
http://oneguytwowheels.blogspot.com/
I'll update it eventually
Thansk
I believe the 3.0si came with the N52 engine.
The 3.0i has the M54.
04R 3l 6 sp VF SC, custom ducting, alphaN, 2.62 pulley, multiport WMI,Severn Tuning(Pokeybritches), Tial BPV,Ceramic header, magnaflow section 1, SS race muffler/y-pipe, megan mounts,42 design catch can, CDV delete ,custom strut bar,3.91 LSD, H&R bars, Hotchkis links.Eibach Pro Kit,Koni Yellows.Megan camber arms. Carbon interior,SSK,UUC lines.CF aero. Poly bushings.
I can't tell from the picture but if it's a black it would be Jet Black. If it's a dark blue it's Black Sapphire Metallic.
Run the vin Thai the dealer
Seller won't give me the dang Vin
Only wants 5k for it though
Thansk
At 5k I would wonder what all is wrong with it. If the car isn't too far away go & check it out. You can get the VIN at that time. I would be a bit worried of any dealer unwilling o give out the VIN.
115k miles.
Has some crappy Bayern wheels on it.
Top doesn't work
Thansk
With the top not working that can get expensive. If you can fix it yourself it can be as cheap as a couple of hundred. If you have a dealer fix it it could be a couple on thousand.
No dealer for me.
Can the top be operated manually?
Thansk
I have a 2004 3.0i and the model number 3.0i or 3.0si should be located in chrome on both sides just behind the side lights. I notice that the hood is not fitting correctly, big gap. Has this car been in a wreck? Seems possible. Yes, there is a way to manually get the top up and down.
