Results 1 to 25 of 33
Thread: Does nobody make wastegate relocation pipes?
    Dec 2016
    Los Angeles, California
    2002 E46 BMW 325i
    Hey guys I need to buy a wastegate relocation pipe to get my wastegate under the car. I see that SPA has one but I haven't seen how it makes the wastegate sit and where it sits. I know a lot of you guys custom fab your own pipe but unfortunately I don't have access to a welder to try and make my own. Would anybody be willing to sell me one? Thanks.
    Aug 2011
    philadelphia PA
    1993 325is
    Are you using a SPA manifold? If I remember correctly their 2 bolt flange is not a standard 38mm flange.
    Dec 2016
    2002 E46 BMW 325i
    Quote Originally Posted by Gmfwd View Post
    This engine will be using a generic maxspeedingrods cast iron bottom mount manifold.
    I have plans to use an SPA but that isn't until after I learn how to tune and turbo this one then rebuild a M54B30 that will then be receiving a SPA.
    Aug 2011
    philadelphia PA
    1993 325is
    Well then dont even consider using the SPA wastegate pipe because it wont fit.
    Unfortunately you are going to have to have someone make it for you or find the tools to make it yourself.
    Apr 2006
    Minnesota eh?
    86 325es
    Unless you buy a kit, a turbo E36 is not quite a bolt together proposition. You have to make stuff.
    Vancouver, B.C., Canada
    '97 M3
    Step one: Buy TIG
    Step two: Turbo your e36
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Or mig.
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    Step 1 : buy turbo
    Step 2 : buy manifold
    Step 3 : ?????
    Step 4 : profit
    Step 5 : new bottom end bc ringlands
    Feb 2014
    Caboolture, Q, Australia
    E39 535i
    Yes. Nobody makes them.
    Sent from my G8141 using Tapatalk
    Aug 2015
    Crystal Lake, IL
    1996 BMW 328i Sedan
    Quote Originally Posted by chikinhed View Post
    Step one: Buy TIG
    This
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Step Zero: Win Lottery
    Step one: Buy TIG
    Step two: Realize you weren't meant to weld
    Step three: Buy someone else's kit in the Classified section
    Step four: Turbo your e36
    fixt
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by milKt View Post
    fixt
    Step five: partout car
    Dec 2016
    2002 E46 BMW 325i
    I have almost everything I need. If I had somewhere to weld, I definitely would love to learn how to do it
    milKt's Avatar
    Cragg is back?
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by armenh7 View Post
    If you have a driveway and an extension cord you have a place to weld. Get a 120v mig welder, a tank of gas, a 4-1/2" angle grinder, and go nuts. I've built several turbo setups with those two tools.
    Dec 2016
    2002 E46 BMW 325i
    I just looked at my fuse panel and it looks like the highest amperage rating I have for an outlet is 20. Is that enough?
    Also, can I use a flux core welder? I know the welds won't be pretty but will it get the job done?
    Apr 2006
    Minnesota eh?
    86 325es
    Yes that is enough amperage. A flux core welder will work to just make a wastegate dump pump. It will look like shit and splatter everywhere but it will make a functional weld. Do your future self a favor though and get a mig machine. You will find it endlessly useful for many years. Look on craigslist for used machines and gas tanks.
    Another option is you can cut the pipes and fit them together with tape, and then take it to a welder or exhaust shop and have them weld it for you.
    Mar 2013
    Upstate NY
    M3
    Buying my Tig was the best idea I've ever had. You can get into one now fully ready for less than 1500$
    '97 M3
    If yer gunna waste moniez on carz ya might az well learn ya some skillz to make all y’allz useful for sumpen.
    Aug 2015
    Crystal Lake, IL
    1996 BMW 328i Sedan
    I bought my AHP China-TIG for about $700 shipped. I’ve had ZERO issues with it.
    So far I’ve made a top mount manifold, a stainless downpipe (ran purge of course), welded and fitted intercooler charge piping, and I just finished up a pie cut 3” aluminum exhaust.
    Even if this China special takes a dump, I’ve MORE than gotten my money’s worth. I taught myself how to weld by watching YouTube videos and paying attention to the guys on this forum. Once you learn how, you’ll always be looking at stuff like “how can I weld something to that??? Lol
    Nov 2008
    Indiana
    97' 328is, 07' Titan
    Step one: Buy TIG
    This is a fool proof plan. It worked for me.
    1997 328is - Megasquirt PNP, Holset HX35, Deka 80lb injectors, SPA T3, Precision PW39 WG, Synapse Synchronic BOV, DKM Organic Twin Disc Clutch, Innovate LC-2 W/B, Mishimoto Intercooler, Mishimoto Catch Can, Mishimoto Rad, Devils Own Meth, Porsche 911 calipers with E46 M3 rotors, Corsa Exhaust
    Dec 2016
    2002 E46 BMW 325i
    I know it's going to be messy as I've watched a lot of videos on it. I honestly would love to get a mig but I live in an apartment and there would be zero room to place the machine and the gas tank for storage.
    Just like this build, I want to learn how to do it properly and then improve with better parts.
    The tape idea is very good. For example, would I just buy all straight tubing and cut it at an angle to have it curve?
    For sure
    Quote Originally Posted by SilburE36 View Post
    Do the pie cuts act as the bends in the exhaust?
    Apr 2006
    Minnesota eh?
    86 325es
    It would be easier to buy a couple mandrel bends and cut them as needed.
    https://www.summitracing.com/search/...er-in/1-500-in
    Dec 2016
    2002 E46 BMW 325i
    There's also this thing I recently came across called steel brazing. Have you ever head of it?
    Aug 2015
    Crystal Lake, IL
    1996 BMW 328i Sedan
    Yeah I know, I like to do things the hard way, lol. I also bought way more 3” aluminum piping than I needed, so this was a way to use it up, learn how to weld aluminum tubing, and practice making pie cuts.
    Yes, the pies are welded together to make a 45 or 90 bend. The cool thing is they can be clocked all over the place to make a bend go up down or sideways.
  1. So why does nobody make 255/35/17 tires for staggered rims?
    By sirius600 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 06-05-2011, 03:48 AM
  2. Does Blaupunkt make a changer that plays CD-R's?
    By Gatorbait in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 02-14-2002, 12:53 AM
  3. Does Hartge make stuff for E36's??
    By Sam L in forum 1992 - 1999 M3 (E36)
    Last Post: 09-24-2001, 10:34 PM
  4. Does BMW make an aluminum pedal set?
    By Greenbeast in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-29-2001, 07:44 PM
  5. Replies: 0
    Last Post: 07-02-2001, 02:56 PM
