Results 1 to 4 of 4
Thread: Low coolant warning.
    Mar 2019
    Mill Creek, Wa.
    2013 BMW 328i, X5
    Hi All, I've a 2013 328i. Recently I get a low coolant warning and chime. Check the expansion tank as the warning suggests, but coolant is at full mark when cold and still coolant is visible when engine is at temp. Never over heats. Recommendations?
    Aug 2008
    North Potomac, MD
    2011 E90 328i
    What is the level in the radiator. Also, my '98 M3 does the same thing. I guess nothing with BMW ever changes!
    Denver, Colorado
    MRster / Z4 M4i / X5 M50
    Quote Originally Posted by JonII View Post
    If the car is telling you the coolant is low, but you can verify it is not, then I would suspect you have a bad sensor.
    2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels. Looking for a new home.
    2022 Z4 M40i, Misano Blue Metallic, Prem Pkg, Driver Assistance Pkg
    2023 X5 M50, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
    Correct. Sensor is bad, seen it a million times. Get a new expansion tank. Replace it, fill it, and bleed the system properly (most important step).
  1. Help low coolant? warning light? refill?
    By Delphin Metalic in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 03-30-2007, 08:05 PM
  2. Engine Management after low coolant warning
    By nazia in forum 1999 - 2006 (E46)
    Last Post: 07-06-2006, 09:04 AM
  3. low coolant warning.
    By hyperknight in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-24-2004, 10:18 PM
  4. low coolant warning light
    By kpytoi9 in forum 1991 - 1999 (E36)
    Last Post: 01-05-2004, 05:07 PM
  5. Low coolant warning on OBC (95 M3)
    By Chongus in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-08-2003, 06:00 PM
