Results 1 to 10 of 10
Thread: metal clip fell into cylinder
    Mar 2018
    Olympia WA
    1995 530i E34 M62 Swap
    Today i was changing my intake manifold and while taking it off one of the metal clips around the electric box that connect to the injectors fell into the valves and then into the cylinder. So now im clueless on what do to and the best way to get it out. Ive tried several thing but no dice
    May 2010
    Honolulu, Hawaii
    '73 E9, '94 E34, '02 E46
    Time for some work with a magnet on a flex stalk.
    Borescopes are nowadays pretty inexpensive and are used in conjunction with your cellphone. One of them would let you see just where in the cylinder the clip went, the better to use the magnet. It might also tell you, if you are really lucky, that the clip isn't in the cylinder at all. 'Course, you'll need them, so the borescope and magnet will help you find the little rascal(s).
    Once in a while, a bit of bent wire with a bit of tape on the end can be used to retrieve things, so you have options.
    Charlie
    Your mission, should you decide to accept it, is to add value to these threads, either by pictures or by descriptions, so the next person with the same or similar problem stands on your shoulders.
    Jun 2014
    northern michigan
    95 M3 - 06 X5 3.0
    Air compressor to the sparkplug hole to blow it back out?
    E36 M3 S50 - E53 X5 M54 - 1980 Porsche 931 - 2001 Impreza RS25
    Mar 2018
    Olympia WA
    ha fuck this piece i got it
    Mar 2018
    Olympia WA
    Thank you for the fast replies btw!
    Feb 2013
    Kalamazoo, MI
    E34 540i6, E46 323i, E36
    Glad it worked out!!
    May 2017
    Perth, Western Australia
    09/90 E34 525i (M50)
    Glad you got it out.
    But how did that clip get loose? I suppose a previous owner pried them off at one time in order to make it loose. You're just supposed to press them in to pull off a plug.
    May 2010
    Honolulu, Hawaii
    More the pertinent question, how did you find and fish it out? I see a bent wire... but no magnet... inquiring minds wanta know!
    Charlie
    Mar 2018
    Olympia WA
    Quote Originally Posted by fo3 View Post
    Im gonna assume when the wire boxes were hanging off the clip slipped off cause i had to loosen the clips to get the wire boxes off
    Mar 2018
    Olympia WA
    Quote Originally Posted by Honolulu View Post
    And i could see the bottom of the clip in the cylinder so i just bent the bottom off a copper wire and hooked it onto it then pulled up until i could grab it with a pair of needle nose pliers
  1. Slave Cylinder Retainer Clip Fell in Tranny!!! Please Help!
    By BrandonTheSaint in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-17-2013, 06:27 AM
  2. Replies: 1
    Last Post: 01-19-2007, 09:43 AM
  3. Need ASAP: Metal Clips from MAF to Airbox
    By jrhaile in forum BMW Parts For Sale
    Last Post: 09-30-2005, 12:03 AM
  4. WTB: E36 M3 Front Brake Caliper Metal Clip
    By Kavkazia in forum BMW Parts Wanted
    Last Post: 08-24-2005, 12:27 AM
  5. Fuel injector head fell into cylinder!!!
    By Phaedrus in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-08-2002, 10:47 PM
