Results 1 to 3 of 3
Thread: Transmission filter kit and fluid
    Feb 2012
    Houston Texas
    2005 BMW X3 3.0i
    What up! Just picked up a 05 x3 with 150k miles. Car leaking trans fluid from pan so thinking of doing the filter fluid change. Any recommend on type of fluid to use?? Thanks in advance!
    Sent from my moto g(6) play using Tapatalk
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    You have to complete your profile with details of the car. 2005 is not enough, which engine type?
    For example if you go to the site of FCP, there you have to select built year, engine 2.5 or 3.0, and in case you select 3.0 M54, there are 2 choices
    GM 5L40-E by GM 5-speed, or ZF 6-speed Manual Transmission GS6X37BZ/DZ
    https://www.fcpeuro.com/
    or check with your VIN on www.realoem.com which trans you have.
    Feb 2012
    Houston Texas
    2005 BMW X3 3.0i
    Thanks. I'm still trying to figure out the app
  1. Transmission Filter Kit for A5S 310Z Automatic Transmission
    By cngzsn in forum Drivetrain & Transmission Parts
    Last Post: 12-28-2010, 11:23 PM
  2. Automatic transmission filter kit
    By e21bimmer320i in forum 1975 - 1983 (E21)
    Last Post: 05-05-2007, 03:17 PM
  3. Transmission filter kit
    By Zac000 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-11-2006, 12:52 AM
  4. Will this transmission filter kit work with a 1998 323is?
    By Topher91 in forum 1991 - 1999 (E36)
    Last Post: 07-21-2006, 05:34 PM
  5. Transmission Filter Kit --Brand New OEM--
    By Charlie587 in forum BMW Parts For Sale
    Last Post: 05-11-2005, 11:50 AM
