Hi,
I have an 01 S54 block with rotating assembly still in place. ~80k miles...The cylinder head was removed years ago and resurfaced, cam caps are there and the followers. No cams or vanos unit included.
The block has some light rust in the cylinders, it will need some work to use. I have not removed any rod caps to inspect bearings, po said the motor was good 5 years ago when I purchased but again it needs work.
Whats included in the sale.....
- 01 S54 Block and Rotating Assembly
- Front Timing Cover
- Cylinder Head as described above
- Metal valve cover bit
$800 for the lot or best offer. You will need to arrange freight or pickup.
502-909-6744
**Price Drop**
$750obo
