Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 84
Thread: Clunk During Shifts
  1. #51
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    The bore of the bushing is out so, there is a big whole in the bushing. I was going to get a razor blade and trim the top of the bushing so the wheel bearing can sit flush on top of the bushing. The wheel bearing fits perfect above the bushing but, no matter how long I put the torch on the subframe, it won't budge. I will try the sawzall to cut the bushing, since there is a whole in the middle of the bushing and I'l have better leverage to cut. The driver side bushing is intact. I'm hoping I get better luck with that one.
  2. #52
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    My sawzal is long. I can only get to the bushing in an angle. My concern is, I might cut the actual subframe. This sucker will not budge. Is there a possibility of melting the bushing onto the subframe?
    I did some cuts with the sawzal but, I'm seeing metal shavings. The center bore is not in the bushing, which has the metal tube. Am I cutting into the subframe?? Or is there metal in the rubber that I'm not aware of?
  3. #53
    Dec 2017
    Chicago Illinois
    2003.5 E46 M3, 1992 e34
    The subframe bushings have metal sleeves. This same thing happened to me when doing my e24s subframe bushings, however I managed to shove a pipe in and it gripped the sides of what was left of bushing and popped it out.
  4. #54
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Do you think I won't cut the frame? That is my fear. I will start sawing and since I can't see how deep I'm sawing, I might cut into the frame.Any suggestions on how I should approach it so that I don't accidentally cut into the frame?Thanks in advance.
  5. #55
    Dec 2017
    Chicago Illinois
    My best advice would be cut, check, cut, check. I think you’d be able to tell once you hit subframe, knicking subframe isn’t end of world.
  6. #56
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Agreed. I'm just worried since I am cutting in an angle, I can't tell if I'm cutting the frame but, I'll do my best and use a pry bar to force the chunks out. Thanks for the advice!
  7. #57
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Still can't get the sucker out. I tried the sawzal but, cutting in an angle, there's only so much I can cut. I put the bearing on top again and heated it up with a torch for almost 5 minutes and it won't budge.
    They make it seem easy when they heat up the subframe but, the bushing won't budge. I have the jack as high as it can go. Not sure what else to do.
  8. #58
    May 2017
    Perth, Western Australia
    some
    Tried drilling or a hammer and chisel?
    I've never done it this way but in the thread I linked earlier:
    5th step: You need to remove the 2 metal pieces on the sides of the bushing. I did this with the drill after I broke my blade on the sawzal. I use the big pliers to pull them out the rest of the way.
    7th step: This is where you use the chisel to cut a line up the side of the metal sheath in the bushing. You can also do this with the sawzal. Once you have cut it all the way, you want to use the chisel to knock the bushing in so that it will loosen and can be removed. Then clean the hole out to where it is nice and smooth. I used 150 grain sand paper.
    That was from south42 and they've already posted in this thread so they might come back with more ideas.
    It should be easy, obviously this broken one was the source of your clunk. When I started looking at e34s and buying one and knowing the first job was going to be suspension I usually searched for aussie videos first and most of what I learnt suspension wise was from this guy (E: used to be aussie fix it or something like that but they changed name as they don't fix anything much anymore LOL)
    https://youtu.be/-HGUVzokpjM?t=143
    Doesn't show you how to install OEM bushings, but shows you how easy the old ones should have come out.
  9. #59
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    I've seen that video 10 times. LOL Interesting how easy the bushing slides out when he heats it. I just tried heating it for almost 10 minutes straight and nothing. I think I will have to jack up the car higher so I can have the sawzal vertical. That should make it easier to cut the bushing.
  10. #60
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    I figured out the problem. The wheel bearing I'm using feels as if it sits perfectly in there but, when I went to pull it out, it's sitting on the frame lip. It seems no matter how I adjust the bearing, it doesn't seem to press down evenly. Now I have to figure out what can I use to sit above the bushing.
    Any ideas on what I can use to put above the bushing that will sit nicely and I can quickly grab from the hardware store?
  11. #61
    Sep 2008
    NYC<-->LI
    '06 X5/6spd 3.0
    If you can saw / hole saw / drill etc the center piece out of the bushing you can fold the outer can (which is metal) in on itself with a prybar or similar tool. If frozen in there, an air hammer would help you to push the first bit away from the frame and get started.
    I would start conceiving methods outside of pushing it out in full form. That doesn’t seem to be working.
  12. #62
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Interesting. I thought the part that touches the frame hole wall was rubber, unless you are referring to the internals of the bushing? The new bushings I have are rubber. 'm going to jack up the car a bit higher so the sawzal fits vertically and I'll have a better angle at cutting. Thanks for the advice.
  13. #63
    Sep 2008
    NYC<-->LI
    '06 X5/6spd 3.0
    It’s been so many years now but isn’t the OEM bushing inside a metal cylinder that you press in? Regardless that is how I remember extracting the outer portion. After drilling up the center with a hole saw and creating space to bend it all out of shape.
  14. #64
    Dec 2017
    Chicago Illinois
    IIRC its an outer metal sleeve covered by rubber.
  15. #65
    Apr 2017
    California
    1989 BMW 535i, 1993 740i
    If you still need a tool, go to pep boys, find/ ask for OEM 25966 this is exactly what I used. Use the smaller of the two sides. Get something sturdy, I used a wooden broom; you will have to pry the subframe to slide it under. Make sure it sits in the center of the bushing, as to not hit the lip. Then proceed as normal, heating around the sides of the subframe till the bushing starts sliding out. It will fall out soon enough. Then repeat on the other side, this time taking 5 minutes hopefully.
    O o
    ____________________________ ______________
    | BLAAAAAAAAAAAAAAAAAAAHHHHHHHH! !!!!
    \_¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯ ¯¯¯¯¯¯¯¯¯¯¯¯¯¯
  16. #66
    Dec 2004
    CT, USA
    e28, e34, e39
    Or you could make one of these,
    demet
  17. #67
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Quote Originally Posted by demetk View Post
    How in the world do I make that? LOL
  18. #68
    Dec 2004
    CT, USA
    e28, e34, e39
    It's made of two off the shelf pullers. I can find the link if you want.
    demet
  19. #69
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    I need to get the bushing off today, because I need the car to go to work. The only stores I have near me are, Adavance Auto, NAPA, and Autozone. Do they rent a tool that would pull out the bushing?
  20. #70
    Oct 2008
    Kettering,OH
    e34 535i and 98 528i
    I would do like in my link and after cutting it a bit use a chisel and a good hammer (3lb) and cut the sleeve.
    Andy
  21. #71
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Quote Originally Posted by south42 View Post
    Andy
    That's what I'm going to do. I'm going to rejack the car high enough so that I can have the sawzal vertical and cut as many vertical cuts as possible and pry out everything.
  22. #72
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Update: I got most of the middle out but, I can definitely see a metal ring outside the bushing that mates with the frame. I'm afraid to cut into that metal, in fear I'l start cutting the frame.
    There isn't a good spot to chisel the metal off, since the metal wraps over the bottom frame lip. I'll keep at it but, this will be interesting, given the space and angle I have.
    I'm not going to even touch the other side. The bushing looks ok for now. Hopefully I can get the bushing out and smoothly put the new one in.
  23. #73
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Still at it. It is a real pain. I've been cutting, prying, yanking and I probably got a 1/3rd of it out in pieces. Now, I'm going to drill. I can't believe how difficult this is and I haven't even touched the other side, let alone the dog bones.
  24. #74
    Dec 2004
    CT, USA
    e28, e34, e39
    These bushings are not easy to remove, that's why people have developed and documented the best ways of tackling them.
    As you have learned chiselling the thing out is a lot of work. I tried once, never again.
    Burning them out? I haven't seen anyone do this successfully.
    Sawzall method works but you need perfect technique not to damage the subframe.
    A puller works but you need to build one, buy one or borrow one from someone.
    demet
  25. #75
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    [QUOTE=demetk;30229636]These bushings are not easy to remove, that's why people have developed and documented the best ways of tackling them.
    A puller works but you need to build one, buy one or borrow one from someone.[/QUOTE
    I'm wondering if I heat up the metal inside the bushing with my heat gun, if it will soften enough to bend with a lug wrench with a flat tip. I don't have a chisel so, I've been using a flat head screwdriver and the flat end of my lug wrench.
  1. Clunking during every shift
    By neovalentine in forum 1991 - 1999 (E36)
    Last Post: 11-01-2010, 04:43 PM
  2. Replies: 10
    Last Post: 03-13-2004, 02:58 PM
  3. Clunk when shifting from 1st to 2nd normal?
    By Mantic in forum 1992 - 1999 M3 (E36)
    Last Post: 08-16-2003, 01:54 AM
  4. Vibration sound during shift
    By MPowered77 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-29-2003, 10:28 PM
  5. Whoosing noise during shifts at redline
    By M3325 in forum 1999 - 2006 (E46)
    Last Post: 08-29-2002, 12:30 PM
