Results 1 to 11 of 11
Thread: Horn Wire Splice
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Horn Wire Splice
    Hi all, 1995 525i 5SPD 283k
    Grandpa is up for inspection. Since I switxched out the steering wheel, I have yet to connect the horn. My old steering wheel had the coiled ribbon. I need to know which wires in the steering column go to the horn, so I can splice a toggle switch for inspection.
    I would greatly appreciate your suggestions...
    Thanks in advance!
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Quote Originally Posted by moroza View Post
    I won't catch the fish for you, but I'll show you where it swims. Enjoy.
    Sifu... Thanks for showing me the path.. Much appreciated..
    Dec 2004
    CT, USA
    e28, e34, e39
    Only 2 connectors got to the ribbon cable. It's not the yellow one.
    demet
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Quote Originally Posted by demetk View Post
    Thanks for the tip!! Much appreciated!
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Ok. This is a pic of the connector that connected to the clock spring connector The air bag connector is tucked away and is orange.
    Is this the horn connector? If so, do I simply cut off the connector and splice in the toggle switch connecting the two brown wires on each end of the switch?IMG_0514.JPG
    Dec 2004
    CT, USA
    e28, e34, e39
    That should work.
    demet
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    That should work.
    Thanks! I am curious that the horn connector has two wires but, the carbon pin has only one.
    I'm wondering how I connect the carbon pin. I'll try to find a write up on it.
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    I found a DIY on this site https://www.bimmerforums.com/forum/s...-Wheel-Installon using the carbon pin but, they only use the brown/red wire to connect the carbon pin. They don't touch the solid brown wire. If that's the case, how is the horn button on the steering wheel grounded if the solid brown wire is not used? There are two wires in the steering wheel that connect to the horn button so, that leaves one wire that connects to nothing. Either the person who wrote that DIY forgot a step that has to do with the solid brown wire, or I'm seriously confused...
    Dec 2004
    CT, USA
    e28, e34, e39
    From what I remember correctly, on the early wheels the carbon pin is connected to the + brown/red wire and the wheel supplies the ground to the steering column which is grounded. You're going to need a slip ring on the wheel and you may not have to worry about the brown ground wire because the steering column should be grounded properly. Check the steering column for continuity to ground with your meter set to ohms.
    demet
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Great! Thanks for the advice! I will do that later when I get home.
    Thanks again!
  1. Horn wire problems after installing 3 spoke wheel
    By STL Avus M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-12-2006, 12:29 PM
  2. Need to know the Horn Wire color for E30!
    By JFV1134 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-17-2005, 07:21 PM
  3. Quickly, what color is the horn wire???
    By JFV1134 in forum 1983 - 1991 (E30)
    Last Post: 07-17-2005, 04:17 PM
  4. Horn wiring with MOMO hub adapter?
    By BMW M Power in forum 1992 - 1999 M3 (E36)
    Last Post: 04-17-2005, 02:27 AM
  5. '99 Ribbon horn wiring for MOMO wheel
    By cmybimmer in forum 1992 - 1999 M3 (E36)
    Last Post: 12-25-2004, 07:22 PM
