Page 2 of 2 FirstFirst 12
Results 26 to 29 of 29
Thread: Go big or go home! 507hp
  1. #26
    Nov 2016
    Hansville, wa
    2001 750il Chrome line
    Metal in the oil, rod knock and Kaboom! You just have to hope for the best based on my research. I have found a few that had new bearings put in and in less than 10k miles metal shows up in the oil.
    01' 750il Chromeline
    95 M3 LS swapped
    07 M5 Manual
    06' M5, Spartan wheels and a 507hp V10
    00' 740il Dinan, CAI, Romulus exhaust, Stage 5 engine and transmission tune, 750 brakes, camber plates, strut tower brace. Sold
    00' 323i wagon for daughter
    03' 525i wagon for the wife, sold
    98' 740i for the daughter, wrecked
    92' 525i with over 200k, wrecked
    02' R1200 CLC, hit by a bus and broken in half. That one made the news!
    It's like herpes there is no cure but if treated properly you can live with it for the rest of your life
  2. #27
    Jan 2006
    Ft. Lauderdale, FL
    98 740il, 00 540i,04 ZHP
    I don't understand how that is happening to some of these engines? The S54 had rod bearing issues and the M5s. What's the deal? The tight tolerances?
  3. #28
    May 2013
    Rochester, NY
    2001 740i Sport
    Quote Originally Posted by racer2086 View Post
    They pushed the rod bearing design, lubrication, etc. to the limits. Hence the 10W-60 oil to somewhat help the issue. As a result, the bearing lifespan isn't indefinite, especially if they've been abused (run hard when cold, etc.)
  4. #29
    Nov 2016
    Hansville, wa
    I definitely will not go until the car is warm. If you put that much pressure on the engine it's not going to be a high mileage motor, a TF dragster gets on pass. I plan on adding a prelube system because most of the wear is at start up. Once the engine is running physics takes care of the rest. I have been reading some BMW hand outs and have discovered that there are five oil pumps on the engine.
    1, pumps the oil from the rear sump to the front sump.
    2, pumps the oil through the oil filter and cooler to the engine.
    3, pumps high pressure oil to the vanos.
    4&5, pump oil from the heads back to the sump when cornering heavy.
    An oil pressure gauge is in the future as well. The main oil feed pump is variable displacement and in my mind needs to be watched.
    95 M3 LS swapped
    07 M5 Manual
  1. To buy big or go home?
    By BigfootSlim in forum 1988 - 1994 (E32)
    Last Post: 04-15-2010, 07:30 AM
  2. E36 with chrome dubs - Go big or go home - Pics too
    By Yellow2 in forum BMW Rides & Events
    Last Post: 03-20-2008, 01:07 AM
  3. Finally, Big Red is home! (Rebuild of the m60)
    By Antrieb in forum 1988 - 1996 (E34)
    Last Post: 11-22-2006, 06:08 PM
  4. Go big or go home?
    By S0nik in forum Forced Induction
    Last Post: 08-31-2005, 04:26 PM
  5. Go Big or Go Home!! T4 is IN! pics
    By diegom6 in forum Forced Induction
    Last Post: 01-15-2005, 07:32 PM
