eBMWParts
Results 1 to 6 of 6
Thread: help with bilstein pss and vorshlag camber/caster plates
    Jan 2014
    Assemini (Sardinia,Italy)
    bmw e36
    Hi guys. last year I bought bilstein pss for my e36. initially I mounted the original top mount, then due to a difference in camber, I was forced to look for specific camber plates for springs like OEM or bilstein. on ebay I bought these used crunchy vorshlag camber plates that I thought went well, but seeing them assembled, I have some doubts. the original rubber that lies below the original plate measures from side to side 14.3cm; the one supplied with the camber plates measures 13.3cm. instead the spring externally measures 14.1cm. I'm afraid the spring can come out of its seat. what do you say?
    Oct 2003
    Seattle
    99 M3
    The 1995M3 and all non-M 36 share the same upper spring diameter.
    The 1996+M3 has a slightly smaller upper spring diameter.
    You could have a spring ‘hat’ for the latter and are trying to mate with the early M3/non-M spring diameter.
    Jan 2014
    bmw e36
    the guy who sold them to me said he had bilstein shock absorbers and springs h & r sport. now I ask him if he had a m3 post 96. mine is not a ///m
    modernbeat's Avatar
    modernbeat is offline Senior Member Supporting Vendor
    Dallas, TX
    Caged
    Just from looking at them, they look like the smaller 1996+ M3 spring perches.
    Jason McDaniel at Vorshlag
    Jan 2014
    bmw e36
    yes guys. I asked the seller and he mounted them on 97 m3. I will cut the seat of the bearing and I will weld it on the non ///M plates. thank you guys, I did not really know this difference
    Oct 2003
    Seattle
    99 M3
    You can buy the proper ‘hats’, from the 1995M3.
    95 M3 Spring “Hat”
    UPR SPRING PLATE 31332227348
    SPRING PAD UPR 3MM 31331128523
    96+ M3 Spring “Hat”
    UPR SPRING PLATE 31332227903
    SPRING PAD UPR 3MM 31332227902
  1. Vorshlag Camber/Caster Plates 1992-1999 E36
    By brakelate in forum Suspensions, Springs & Shocks
    Last Post: 05-04-2009, 08:43 PM
  2. Vorshlag camber/caster plates for e36 M3
    By olds350 in forum Suspensions, Springs & Shocks
    Last Post: 01-26-2009, 08:41 AM
  3. Vorshlag camber caster plates for 96-99 E36 with brand new spring perches
    By Hugo in forum Suspensions, Springs & Shocks
    Last Post: 12-30-2007, 02:18 PM
  4. Vorshlag Camber Caster Plates w/2 sets of spring perches - nearly new!!
    By E36M3E in forum Suspensions, Springs & Shocks
    Last Post: 12-10-2007, 03:30 PM
  5. FS: Ground Control Coil Over Kit w/Vorshlag Camber Caster plates
    Last Post: 05-31-2007, 01:02 AM
