Results 1 to 25 of 29
Thread: Power Steering Pump: Whining & Seeping
    Jan 2016
    Venice, CA
    1991 850i
    Hello All,
    I did a search but couldn't find enough info to get clarity on this.
    I have a 91 850i, and had it inspected a few months ago. The mechanic found a very faint whine in the power steering, but only while the engine is cold. He said he wouldn't worry about it for now, but that's not really my style.
    Since he pointed it out to me, I have been wanting to fix it. I looked underneath the car and found that the underside of the pump is wet. Not a bad leak with a drip, but a faint seep that over time had left a thin coat of fluid coming off of it.
    Here are my questions:
    1. Bad hoses/connections can cause the leak, could low fluid cause the whine?
    2. Does the whine mean the pump is going bad, or could it be attributed to low pump fluid?
    I am going to have a closer look at the pump to see if it might be the hoses. I just don't want to replace the hoses if the pump is bad and vice versa.
    '91 850i 6spd
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Old hoses can cause that too, they swell over the years like old brake hoses. Also old power steering fluid with dirt, moisture inside. Or dirty filters in the system, or in the gear box bottom, pics here of the metal filter on my website, click on the left fixes and go to steering http://twrite.org/shogunnew/topmenu.html
    Just yesterday someone on a German forum solved a steering problem, he even changed the power steering pump, did not help, problem was a clogged filter = not enough fluid was flowing.
    Here you see the filters in your system http://www.realoem.com/bmw/enUS/part...MW-850Ci&mg=32
    And there is no need to replace the pump, there are gasket/seal kits which include the profile gaskets. I have repaired already a lot of these pumps with new gasket kits.
    ZF Recommended Steering Systems Flushing Procedure
    ZF says: A steering system is an important safety component in a vehicle and must be properly maintained. With this in mind, a steering system must be flushed EVERY TIME a component of the system gets replaced, no matter if the components are new or remanufactured.
    Equipment Needed:
    - Safety Glasses
    - Empty Bottle for contaminated oil
    - Screwdriver
    - Manufacturers’ Recommended Power Steering Fluid
    1- Clean the outside of the oil reservoir and the surrounding area to ensure no dirt or foreign particles get into the oil reservoir.
    2- With a screwdriver, loosen the clamp holding the return line connection between the steering gear and the oil reservoir. Disconnect the oil line from the oil reservoir.
    3- Insert the end of the return line into an empty bottle and cap the oil reservoir return connection with a plug.
    4- While wearing safety glasses, start the engine and fill the oil reservoir with fresh power steering fluid while turning the steering from side to side to purge all oil out of the system. (Use recommended fresh fluid to flush the system.)
    5- Turn off the engine and remove oil reservoir from bracket. Flush out debris or particles from reservoir into container. Check oil contamination for metal or foreign particles by filtering the contaminated oil with a coffee filter.
    - Fine metal shaving means a normal wear and tear of the power steering pump.
    - If metal chips are present, replace power steering pump.
    - If black rubber particles are present, the pressure/return line inner lining is disintegrated. Replace the pressure/return line.
    6- Check the oil reservoir condition for cracks. If the oil reservoir is cracked, replace the oil reservoir. If reservoir has no cracks, just replace the oil filter. If filter is integrated inside the oil reservoir and cannot be removed for oil filter change, replace entire reservoir.
    7- Check the condition of the pressure/return oil line for cracks, soft or sweat spots. If any of these conditions exist, replace lines.
    8- Check all banjo bolt connections for blockage. If blocked, clear connections by appropriate method (air hose, fluid, etc.)
    9- Reconnect oil reservoir into bracket.
    10- Connect return line to oil reservoir.
    11- Top off oil reservoir with manufacturers’ recommended fluid.
    12- Start engine and turn steering from lock to lock to purge air out of the system.
    Caution: Do not hold steering gear from lock to lock for more than 30 second. This could cause the steering system to overheat.
    12- Check for oil leakage and top off power steering fluid to recommended level.
    The smallest particle can cause the system to leak or even fail. A clean system is a REQUIREMENT for acceptable service life.
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Change Fluid and Filter
    Old is on the Left New is on the Right
    Jan 2016
    Venice, CA
    1991 850i
    Thanks for the replies. It was a quick look prior, and upon going back under there I realized it was the AC compressor that was wet in oil, caused by timing chain tensioner. I just ordered the parts to replace/repair that.
    Back to the power steering pump. It is dry, as are all the lines. I still have the very faint whine though, so I want to replace the filter. Is draining the fluid required for a filter change? if not, do you recommend it anyway?
    '91 850i 6spd
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Pentosin
    There some pretty good tutorials out there on changing the fluid but you should get as much out as you can. Turkey Baster will minimize the mess.
    Jan 2005
    Japan
    Pump the brake pedal till it get's hard, then all the Pentosin is out of the H31 brake bomb and the Pentosin container is full, then use a turkey buster and suck the Pentosin container empty, then you have already about 50% out of the complete system. Then clean the filter at the bottom of the steering gear, so also the fluid inside the steering gear will drain, with that procedure you will have a lot of old fluid out already.
    Refill, drive some time, check the fluid again, if still dirty, same procedure as before with the turkey buster.
    I would not touch the hydraulic hoses if they are dry.
    Indianapolis, IN
    93 850Ci, 09 Caddy SRX
    Quote Originally Posted by shogun View Post
    Thanks! Nice procedure.
    1993 850Ci.....18 years & 165,000 miles and counting!
    Jan 2016
    Venice, CA
    1991 850i
    Thanks Shogun... Great direction. I'll be doing it this weekend. I agree about the lines, I was hesitant to agitate dry lines.
    I found the pictures of the steering gear filter on your site. Big help.
    Once fluid has removed/drained, strainer cleaned, filter replaced, do I need to bleed the system when filling?
    '91 850i 6spd
    Jan 2005
    Japan
    Quote Originally Posted by Bsangerman View Post
    no need, that is self bleeding, see in my post above item 12
    12- Start engine and turn steering from lock to lock to purge air out of the system. Caution: Do not hold steering gear from lock to lock for more than 30 second. This could cause the steering system to overheat.
    Jan 2016
    Venice, CA
    1991 850i
    Awesome! Super helpful per usual.
    '91 850i 6spd
    Jan 2016
    Venice, CA
    1991 850i
    Hey Shogun-
    How do I gain access to the steering gear?
    I've got the pentosin container empty, but can't find access to the steering gear to clear the screen/filter
    '91 850i 6spd
    Jan 2016
    Venice, CA
    1991 850i
    Ok- I found access to it, however I do not see the servotronic torque converter. Is it possible I don't have that?
    Mine looks like this:
    http://www.realoem.com/bmw/enUS/show...diagId=32_0294
    NOT this:
    http://www.realoem.com/bmw/enUS/show...diagId=32_0287
    And if that's the case, is there another point at which I can drain the remaining fluid?
    '91 850i 6spd
    San Francisco, CA
    1972 3.0 CSi-1988 M6
    Hex drain plug (use hex Allen wrench) at the bottom of power steering pump.
    Bert
    91 850i-A
    1972 3.5 CSi (L-jet, Getrag 265 5 speed)
    1988 ///M6
    2021 X3 M40i
    The back to back BIG COUPE” duo
    Jan 2016
    Venice, CA
    1991 850i
    Thanks. Drained it tonight. There was a blue sealant on the threads. Do you know what that is?
    '91 850i 6spd
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    Blue Loctite on drain plug. Use liberally.
    Replace the filter in the small cartridge on the front of the oil pan too, most people ignore this and it makes a big difference. #13 on this diagram
    http://www.realoem.com/bmw/enUS/show...diagId=32_0299
    As for your leak.... the pump is the lowest part of the system, so it isnt necessarily the origin, but it is a good place to start. If you undo the banjo bolts connecting the hoses to it, replace the crush washers with new ones - do not re-use these. You can order assorted sets of these on Amazon for minimal cost.
    As for the hoses themselves... there are only 2 true "pressure" hoses in the system, the rest can be rebuilt with basic tools and clamps. Don't get too carried away, there is a lot of them... but it is usually the non pressure hoses that start to leak. Take your time to track down the culprit(s)
    ...and Shogun is telling you to not hold the steering WHEEL in full lock (turned all the way left/right) for too long when bleeding the air
    Jan 2005
    Japan
    Quote Originally Posted by cartoonz View Post
    standard procedure for E36 M3 drivers, here some instructions
    http://www.gvc-bmwcca.org/_download/...eeringHose.pdf
    https://photobucket.com/gallery/user...MzA4OQ==/?ref=
    You should also try to get into the habit of getting hose clamps with rolled edges, instead of the flat band style. It will help in avoiding deformation of hoses.
    https://photos.smugmug.com/MotoIQ/Te...P1050066-M.jpg
    https://photobucket.com/gallery/user...MjcuanBn/?ref=
    https://photobucket.com/gallery/user...MzAuanBn/?ref=
    https://photobucket.com/gallery/user...NDUuanBn/?ref=
    https://photobucket.com/gallery/user...MzguanBn/?ref=
    http://farm4.static.flickr.com/3367/...b0e80cde_b.jpg
    https://photobucket.com/gallery/user...ZXMuanBn/?ref=
    did that on my E36 M3 too http://e32b12.blogspot.com/search/label/M3
    and also on my E32 750 which uses the same power steering pump as some E31, feed and return lines do not have high pressure
    Jan 2016
    Venice, CA
    1991 850i
    Thanks Cartoonz- good recommendation! I just ordered it, so I'll be replacing fluid with 11S and changing the cartridge filter and pentosin container filter.
    Turns out there were no leaks, so not going to mess with any of the lines. Hopefully, the above sorts out the faint whine I had.
    '91 850i 6spd
    Sep 2008
    Santa Barbara
    ...I'll be replacing fluid with 11S...
    While you CAN do this, you may want to rethink doing it at this point.
    Here's why...
    CHF 7s is mineral based, 11s is synthetic. This is why you CANNOT mix them.
    Yes, you CAN use the 11s but you must very thoroughly flush the entire system of the original 7s.
    This involves several complete system flushes to accomplish.
    Some say that switching from mineral to synthetic reacts with seals/hoses somehow and leaks may happen where there were none before, but I'm not sure what to think of that theory.
    So, unless you bought a case of the CHF11s, you might consider sticking with what BMW intended... and yes, it IS available, Febi makes it.
    I've done this switch on a couple of cars, but there really is no advantage to doing it. The 11s really isn't magically better than the 7s in any perceivable fashion.
    '91 850i 6sp (mint) (sold)
    Sep 2018
    Belgium
    1990 850i and 1970 2800C
    sorry , a bit of topic.... but why does the pressure line for the ASC+T go's ( needless ? ) all around the engine ??? just to have a suitable place for the filter … ?? It involves 2 flex hoses… to reduce the "pulse" pressure from the pump ?? i just wonder....
    Sep 2008
    Santa Barbara
    Quote Originally Posted by Belgiumbarry View Post
    I suspect that the longer length of hard line has something to do with that funtion.
    Jan 2005
    Japan
    Probably has a different reason, maybe just available space. I was wondering about this line around the engine last year when I had to replace it because of leaks. My 89 750 does not have ASC+T. On my car that line around the engine is for the rear self leveling. From power steering pump on left side engine bay 1 x around the engine oil pan to the next connection point left side http://www.realoem.com/bmw/enUS/show...diagId=33_1553 11 Feed line 37131137458 ENDED/NLA. As that line is a high pressure line, I sent it to a shop here in Japan which replaced the high pressure hydraulic hoses and recrimped them. In that area 130 bar! Checked the original hoses of that line, it is designed for 180 bar bursting pressure.
    The shop now installed for me new hoses suitable for max 220 bar.
    Jan 2016
    Venice, CA
    1991 850i
    Here's why...
    I was going to do a full flush thinking the 7.1 wasn't available, but now seeing the Febi CHF 7.1. 6162, correct?
    Thanks for the heads up.
    '91 850i 6spd
    Jan 2005
    Japan
    correct, that is the mineral based oil like CHF 7.1
    The equivalent to CHF11S synthetic is Febi 06161
    Sep 2008
    Santa Barbara
    use the Febi M 6162, or 06162 (same thing), CHF 7.1
    You can actually get this from your local NAPA store for a bit over $7 a bottle right now...
    Cave Creek, AZ
    1993 850ci 2001 M5 / Z3M
    Cartoonz, odd question, when you use the blue loc-tite on the drain plug, is there any special technique or just liberally coat the threads. I usually drain the system from the plug, but of course a friend's car seems to always want to leak from that thread after we did a drain and fill.
    Does anyone have a replacement part number for that plug?
    Regards,
    Brian
    Cave Creek, AZ
  1. New power steering pump whine
    By davisenvy in forum 1996 - 2003 (E39)
    Last Post: 12-16-2020, 08:10 AM
  2. No more whine - replacing the power steering pump
    By Malcolm in forum 1991 - 1999 (E36)
    Last Post: 11-30-2010, 12:25 AM
  3. power steering pump whining
    By cj08334 in forum 1988 - 1994 (E32)
    Last Post: 03-22-2008, 09:28 PM
  4. power steering pump death whine, rebuild or?
    By Hurley68 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-06-2008, 01:22 PM
  5. Power steering pump leaking/whining.
    By Lorgow in forum 1991 - 1999 (E36)
    Last Post: 11-11-2004, 01:19 AM
