Hey guys, I shut off my e23 when I was driving sue to the temp gauge going up, as I tried starting back up I got nothing and have been getting nowhere since, the symptoms are the fuel is pouring out from underneatg the breather on the intake. Can’t seem to figure this out, before this issue I changed the fuel pump cold start valve, and verified that the ecu has no damage, really wanna get it back on the road, please help guys!!
moved to E23 forum from 7 series general forum
You did it for me? I’m unfamiliar with how to do that
Yes, your thread has been moved. What year is your e23?
It’s an 87’ I just confirmed earlier I’m not getting any sparks either
My assumption after running some more tests, bearing in mind I’ve changed the 2 reference sensors for the flywheel, checked for spark and was unsuccessful, I’m thinking it could be the pin on the flywheel has maybe came off, my next move will be to manually turn the engine and see if it is on.
Have you checked or replaced your main relay? Some of them use two sets of contacts, if one set fails you can loose spark but not fuel. This also happens if the wrong type of relay is used. Took me a while to figure this out on my project car as it had the wrong relay.
1983 BMW 733i My current project (or at least one of them)
2003 Volvo V70 5 Speed Current Daily Driver
1993 300TE 4Matic Project wagon -sold
1997 E290 Turbo Diesel Wagon -traded for above, an amazingly comfortable car to drive, great drivetrain, but the rust, oh my god the rust
1992 BMW 525i -traded in
1990 Silver 300TE -Sold Loved the wagon, hated the M103
1985 Grey 380SE Diesel Conversion, 2.47 rear end, ABS -Sold, really should have kept this one
1979 Silver 300D "The Silver Slug" -Sold
Did you solve the fuel leak issue?
