RM European Auto Parts
Page 3 of 3 FirstFirst 123
Results 51 to 64 of 64
Thread: 02 330i auto project
  1. #51
    Sep 2009
    Fallon, NV
    1995 525i 5 speed
    No I haven't, thanks D.
    Also, I decided to drive the car some. Previously there was 4 codes, all in the EGS. There are SO many now. I will make a list and post it later.
    Thanks again.
  2. #52
    Sep 2009
    Fallon, NV
    1995 525i 5 speed
    I wrote down the codes, but not the descriptions. DME - EA, 8F, E1, EB, E4, A8, E3, CB, CA, F2, F3 EWS - 2F, 0F LEW - 1 SPMFT mirror memory, driver - 4, B SZM - 4, 5, 6 IHKA - 0, 1, 2, 3, 4
    KOM - 11, BE, 87 LSZ - 22, 3F, 41 RLS - 80 ZKE - 7, 2A, 33, 3D, 30, 85
    I didn't list the EGS codes already discussed in this thread. I also didnt list MRS codes as they are all related to my seats not being wired.
  3. #53
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Well you do have a seat memory code, so that tells me there is no communication happening. I would check to see if there was a break in years, for sometime BMW will move wires around a connector at facelift time.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
  4. #54
    Sep 2009
    Fallon, NV
    1995 525i 5 speed
    After I grab the seat connectors with as much wire as I can, Ill get them hooked up. then see if any seat related codes remain. I have to go through the list and see what I need to fix them. I'm most interested in whats wrong with the engine. but I'll get there sooner or later.
  5. #55
    dworthy's Avatar
    Nov 2010
    Well, you need to put words with those DME codes, as I don't carry around in my pocket the code sheets.
    Darin
    Current:
    Past:
    M-Flight Member
  6. #56
    Sep 2009
    Fallon, NV
    1995 525i 5 speed
    sorry about that D, I was tryin g to hurry and write the codes down before I had to leave. I'll go through the list today and write out descriptions and repost later on.
  7. #57
    Sep 2009
    Fallon, NV
    1995 525i 5 speed
    These are the DME codes.
    EA - 234 catalytic converter overall efficiency bank 2
    8F - 143 tank ventilation or tank leakage
    E1 - 225 car efficiency bank 1
    EB - 235 lambda heater bank 1 past cat or pre cat signal
    E4 - 228 mixture deviation bank 2
    A8 - 168 pedal position sensor pot 1 or MAP coming thermostat jammed
    E3 - 227 mixture deviation bank 1
    CB - 203 lambda regulation bank 2 post cat
    CA - 202 lambda regulation bank 1 post cat
    F2 - 242 misfire cylinder 5
    F3 - 243 misfire cylinder 6
  8. #58
    dworthy's Avatar
    Nov 2010
    Yeah a whole can of worms there chap!
    So lets start with the most obvious to me. Oxygen sensors, as you have several, are they original?
    Tank vent, open the gas cap and inspect the flat gasket. It should be smooth, and free of any cracks.
    Mixture deviation can mean a vacuum leak
    Misfires could be anything from spark-plugs to coils or faulty injectors. Let look at the coils and plugs first.
    Lastly, I am sure you cleared all the codes, and there are the ones that like to come back after a 10-20 minute drive?
    Darin
    Current:
    Past:
    M-Flight Member
  9. #59
    Sep 2009
    Fallon, NV
    1995 525i 5 speed
    When I originally checked codes I only got the EGS codes. I had driven the car a little over a few days. And then when I checked again it had all these. I would assume the parts on it are original.
  10. #60
    dworthy's Avatar
    Nov 2010
    The recommend replacement interval is 120k miles on the oxygen sensors, so if you are past that, it would be due.
    Darin
    Current:
    Past:
    M-Flight Member
  11. #61
    Sep 2009
    Fallon, NV
    1995 525i 5 speed
    I'm starting to wonder if I can find an engine and manual trans to swap in for a decent price...and what a decent price is. Local shop is $100 for a smoke test. I wonder if there's a head/HG problem.
  12. #62
    dworthy's Avatar
    Nov 2010
    I don't think so, as these cars are pretty solid if you don't overheat them, and do the routine maintenance.
    There are smoke machines on ebay for about that cost, so if you ever have to do it a second time, it has paid for itself.
    Darin
    Current:
    Past:
    M-Flight Member
  13. #63
    Sep 2009
    Fallon, NV
    1995 525i 5 speed
    I honestly don't know if it was ever overheated. I assume if it was maintained, that it was following guidelines. But the engine doesn't seem terrible. I just want to get it running nice and 5 speed swap it. Switching between the cars made me decide that I want a standard, even if it sometimes makes my leg hurt. I hate autos, never drove a newer auto.
  14. #64
    Sep 2009
    Fallon, NV
    1995 525i 5 speed
    Without Chris around, I'm looking at what you say, d. You're the only other Ive seen as much on here. Any recommendations for a smoke machine from Amazon? The smoke in this video bothers me.
  1. Should I buy this 02 330i 185k miles for a project (3rd car)
    By RobGeeLau in forum 1999 - 2006 (E46)
    Last Post: 06-27-2018, 05:34 PM
  2. FS: 02 BMW 330i Auto 4dr, Silver, 47k miles, excellent condition, clean Carfax
    By asduncan23 in forum BMW Cars For Sale / Wanted
    Last Post: 06-20-2007, 10:42 AM
  3. 01 330i auto or 02-03 MCS?
    By D1AllTrac in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-09-2005, 05:43 PM
  4. 330i auto vs 850 turbo auto
    By suspenceman in forum Kill Stories
    Last Post: 07-11-2002, 07:19 PM
  5. 330i auto vs. 850 turbo auto
    By suspenceman in forum 1999 - 2006 (E46)
    Last Post: 07-08-2002, 05:07 PM
