Results 1 to 25 of 58
Thread: Front Lower Control Arms NLA?
    Feb 2002
    Houston, Tehas
    99 Mcoupe
    Per the established wisdom, I try to replace my front lower control arms every ~5 years or so with track and autox use.
    I guess I haven't been shopping in a while, because it's looking like the OEM/Lemforder 96+ e36 M3 castered control arms are out of stock or on "indefinite backorder" almost everywhere.
    I'd rather not use Meyles, the quality really isn't up to snuff next to the OEM ones.
    Is this becoming a real issue now? I know club racers recommend replacing the LCAs every ~2 seasons, What are people doing for control arms?
    BKLYN, NY
    98 M3/4/6, 16 M3/6
    Are u sure? Have you tried fcpeuro?
    https://www.fcpeuro.com/products/bmw...z3-31122228461
    You could also replace the balljoints with e30 balljoints if they truly are NLA.
    Oct 2003
    Seattle
    99 M3
    Yikes!!!
    Meyle FLCA replicates the 1995 E36 M3 FLCA geometry (and non-M3.)
    The 1996+E36M3 FLCA geometry is different than the 1995E36M3 FLCA geometry.
    Springfield, IL
    '95m3(Avus)/996tt/4.8is
    Just use Meyle arms with offset fcabs or replace the ball joints with e30 lemforder joints.
    Nov 2001
    Parker, Colorado
    GTS3 E36, 97 M3/4/5
    The Lemforder arms have been MIA since early 2018. Meyle HD are available at FCP and Turner (only in kit-form as of yesterday when I ordered them). OEM arms (the link above) are crack money at > $300 each!
    Oct 2003
    Seattle
    99 M3
    I see some on-line retail outlets have replaced Lemforder with MTC. Any chance they are the correct geometry for 1996+ E36M3 and at least as good as Meyle?
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by John in Houston View Post
    The Lemforder OEM arms (the link above) are crack money at > $300 each!
    Makes the Lemforder lightweight aluminum E46 arms look inexpensive.
    Oct 2003
    Seattle
    99 M3
    LOL!!! The $300+ 1996+M3 BMW/Lemforder OE FLCAs are on ‘national backorder’, supposedly till mid-May.
    Nov 2005
    MA
    Cayman S, Golf GSW, E30
    I use the Meyle HD arms with offset LCABs. Work great and is what Bimmerworld recommends on race cars. They use the larger ball joint with no rubber isolater like the M3 ones. Only $110 each.
    Don't forget to replace them every few seasons.
    May 2009
    Richmond, VA
    Spec3 & MCoupe
    I just did the E30 ball joint swap. If you have access to a press, it's not a very difficult job. Also, it's quite cheap. I think I paid about $30 (x4) for the ball joints.
    Jul 2014
    metairie, la
    1999 e36 M3
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by hc1001 View Post
    Most likely these MTC FLCAs are the 1995M3/non-M3 FLCA geometry, though the FCP page (linked from above post) does indicate 1996+M3 application, I’d like get conformation of the geometry.
    IF they are in fact 1995M3 geometry, they should be coupled with the 1995M3 FLCA Bushings to replicate the 1996+M3 caster.
    Does MTC also have FLCAs for the 1995M3?
    Aug 2003
    Dallas, TX
    Z3M, X5M
    Suppose I'll replace the ball joints from the old worn control arms I have in storage
    Are these Lemforder E30 inner ball joints good for E36 M3 control arms?
    https://www.fcpeuro.com/products/bmw...r-31121126253l
    -Phil
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by Z-Thrizzle View Post
    Yes, you should be fine, though I have heard that the E36 got a larger Inner Ball Joint.
    FYI - E30 FLCAs are same geometry as ALL E36, except 1996+M3.
    Non-M FLCAs for E36 have rubber isolated Outer Ball Joint.
    Sent from my iPad using Tapatalk
    Sep 2008
    NS, Canada
    E36 M3
    Bumping because I bent an arm and MTC appears to be the only option - has anyone tried them, or at least confirmed they are correct geometry? All the usual sites are listing the OEM arms as NLA.
    Oct 2003
    Seattle
    99 M3
    1995 M3 FLCAs plus Offset FLCABs should work, countless folks have used this approach.
    Meyle HD FLCAs (w/solid Outer BJ) with Offset FLCABs should also work.
    Jury is still out on MTC.
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by TXBDan View Post
    OE 1995M3 and OE 1996+M3 FLCA both have solid outer BJs, unlike the OE (and most aftermarket) 318/325/323/328 FLCAs, that contain the rubber isolated outer BJ.
    Bergenfield, NJ
    '99 M3 '10 X5 35d '02 M3
    As a data point, BMW's internal parts ordering system has had 500 left and 500 right FLCAs listed as arriving in three months since at least Feb. Each month it get kicked outwards so delivery is always three months out. While they are not listed as NLA, I think we can count these as dead.
    Sep 2008
    NS, Canada
    E36 M3
    Quote Originally Posted by bluptgm3 View Post
    1995 M3 FLCAs plus Offset FLCABs should work.
    Meyle HD FLCAs with Offset FLCABs should also work.
    Yeah, I'm aware other arms will work but I am trying to stay class legal. I might just try an MTC if I can't find some used arms to put new balljoints in.
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by Crustashio View Post
    Are the 1995M3 FLCAs plus offset FLCABs not class legal?
    I would think alignment sheet should be good for showing similarities to 1996+M3, in light of the ‘shortage’.
    Sep 2008
    NS, Canada
    E36 M3
    For SCCA street touring autoX LCAs must be OE if you use camber plates. Someone on another forum indicated they bought MTC and were actually 96-99 geometry, so I am going to try them.
    Nov 2005
    MA
    1995M3 and 1996+M3 FLCA both have solid outer BJs, unlike the 318/325/323/328 FLCAs, that contain the rubber isolated outer BJ.
    Unless its a Meyle HD control arm which has the solid outer balljoints just like the M3 ones.
    Oct 2003
    Seattle
    99 M3
    True.
    Curious to see how the MTC FLCAs pan out on a 1996+M3 w/Centered Bushings.
    How are the BJs?
    BMW 1995M3 FLCAs w/BMW Offset FLCAs are OE.
    Bergenfield, NJ
    For clarity, the closest alternative to the 96+ M3 arms that will still work with centered FCAB are the HD Meyle ones, yeah? IE, these - https://www.fcpeuro.com/products/bmw...36-fcp-e36arms
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by BlackHawkRacing View Post
    You should use Offset FLCABushings with Meyle HD FLCAs for 1996+M3 to get (close?) to same geometry.
    There has been a suggestion that the MTC FLCAs are the 1996+M3 geometry, but I’d like to get firm conformation.
  1. How-to on Front Lower Control Arm Bushings???
    By UNVMYM3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-12-2009, 08:02 AM
  2. Front lower control arm bushings
    By M3RACER in forum 1992 - 1999 M3 (E36)
    Last Post: 05-24-2007, 09:06 PM
  3. FS: 96+ M3 front lower control arm bushings
    By LEVOC///MPower in forum BMW Parts For Sale
    Last Post: 04-27-2006, 01:02 PM
  4. Front lower control arms / Bushings
    By Dinanify in forum 1992 - 1999 M3 (E36)
    Last Post: 06-18-2003, 05:58 AM
  5. GC Front Lower Control Arm Bearings
    By siastuning in forum BMW Parts For Sale
    Last Post: 06-12-2003, 02:19 PM
